Question about Relisys RLT1720 17" LCD Monitor
Monitor problems i have a dell 2350 and when i turn the computer on the green light comes on just for a moment and then it turns red again.the front panel lights blink green.i can't use the computer unless i am in safe mode.thanks.
  • 81 Answers
It seems that you are trying to use a graphic mode that your monitor doesn't support.
Restart windows in safe mode, go to Control Panel. Click on Display. Select settings and change to a resolution that is supported by your monitor (I don't know your model, but 1024x768 is a safe bet).
Restart the computer.
It should be working by now.
Posted on Dec 21, 2008
LCD monitor turns off
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this?
Nov 02, 2012 | Computers & Internet
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Monitor shuts off but green light stays on
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
52 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
