Question about Sport & Outdoor - Others
Timing had to change out water pump in order to do so had to remove timing belt tryed and tryed again to lineup correct timing wanted to start but didnt im fed up can you help me
  • 6,982 Answers
Set timing on what??? I'll give you a generic answer pertaining to engines: Cam & crankshafts carry a index marks on them. Cam gear is indexed to a mark on the cylinder head, crankshaft indexed to "0" degrees on main damper pulley/timing mark on cover scale.Or, they are indexed to each other, example: Chevy smallblocks : cam gear indexes straight down to crank gear@straight up position (which is also, "0" when checked on timing index pad on cover) This info can be found in any general repair manual. A more complex way to establish positions is with dial indicators and a degree wheel, but in most cases this is unnecessary!
Posted on Dec 23, 2008
Just changed the water pump on a 2005 dodge neon and now it wont start. What could it be
You're not giving much to go on. Is it a 2.0L or a 2.4L?
You say it won't start. Does it turn over and not fire, or does it just sit there and do nothing when you turn the key?
Both engines require you to remove the timing belt in order to change the water pump. The 2.0L is definitely an interference engine, and I'm not sure about the 2.4L. But if the timing belt was not re-installed properly, it will result in a no-start condition since the valves will not be in sync with the pistons and spark. Best case scenario you correct the issue and are good to go. Worst case scenario is that if the belt is out too far, you bent valves and have to service the head(s).
May 31, 2016 | 2005 Dodge Neon
Hello,my 2000 odyssey leaks oil.guy said its front oil seal but im gonna need time belt,water pump,vtec valve and oil pan gasket.Do i really need all that just to change front seal? $400 for labor?
A leaking front seal will allow oil to get into the area where the timing belt is located. This will cause oil to get on the belt and can cause damage. Since the timing cover must be removed to access the front seal, it is recommended to replace the belt while you are in there. Also, the water pump is driven off the timing belt. Replacement of the water pump is always recommended when replacing the timing belt for two reasons. First, it is easily replaced at this time and it is good preventive maintenance. Secondly, the water pump bearing is under tension from the timing belt and develops a wear pattern. Replacement of the belt without replacing the pump will cause the new belt to wear the bearing in a different pattern, often causing leaking in a very short time after the replacement. This would then result in having to repeat all the labor again to replace the pump. It is easy to see that for $400.00 labor, you don't want to do that again in only 2-3 months. as far as the VTEC valve is concerned, I don't see a relationship to the oil leak. It could just be something else the mechanic found during the inspection. I can find nothing in the remove/replace procedures that requires replacement of the oil pan gasket. Again, maybe something additional that is needed from visual inspection, but not needed for the front seal.
Apr 03, 2016 | 2000 Honda Odyssey
I have a 1998 volkwagon beetle 2.0 that needs a water pump so i buy the water pump install it put everything back together and put water inside then it just spilled out. tried to start it and now the
you should did your home work before removed old water pump most vw engines water pump is part of the timing belt assembly so when time to replace around 80k miles you should order complete timing belt kit which includes water pump with it.
so after you finish up if you didnt try to hard to run engine you may or may not damage any piece from your valve train!!even with all proper parts you have on your hand you still need high cost speciality tools to complete timing belt replacement on that engine recommendetion is tow your vehicle to mechanic shop and let them do it for you it will save you time and money!
good luck!
Feb 12, 2012 | 1998 Volkswagen Beetle
1999 dodge durango 5.9 v8 loud squealing noise from under hood replaced tenison pulley, idler pulley, ac pulley/clutch assembley,and belt please help
You didn't mention the alternator, power steering pump, or water pump. In fact, any pulley other than the crankshaft one can have a bad bearing or dry seal. Remove the belt and spin each pulley while listening for any rough noise or squeal. If it was the crankshaft, it might be time to check the oil. Start the engine with the belt off to see if it does squeal. Make sure the noise isn't coming from the radiator fan(s).
Nov 17, 2009 | 1999 Dodge Durango
I want to replace the timing belt on my Subaru Impressa Outback with the 2500 cc motor and want to know if it recommended to replace the water pump at this time.
not to bad a job, the manuals make it sound worse than it is, remove radiator ( better than damaging it ),all the pulleys have timing marks on them that align with marks on heads also the new belt will have marks on also ,which also lineup with marks on the pulleys, if needed this is a good time to replace the camshaft seals ,if the water pump needs replacing then yes its agood time to do it ..
http://manualfile.com/Automotive/Subaru/
a good site that has a manual for you
Nov 12, 2009 | 2003 Subaru Impreza
Timing belt jumped... why?
This can be caused by not tensioning the belt corectly.When fitting a new belt you should allways replace the tensioner,and make sure the water pump pulley is in good working order.Its always wise to get your timming belt from the dealer.as others are nown to be faulty.Fit new belt follow manuel when doing so.good luck
Aug 01, 2009 | 1998 Ford Escort
Changed timing belt 94 civic ex 1.6, now wont start
first make shure the fireing order is correct 1 3 4 2, make shure you have the timeing set right
Apr 02, 2009 | 1994 Honda Civic
Do you have to change the timing belt when changing water pump
yes in this case it is correct, the reason is that the water pump and the timing belt runs toghter.. you dont want to change one without the other..
Mar 20, 2009 | 2004 Hyundai Tiburon
How do I change the water pump on a '91 capri?
its pretty easy to do so all you have to do is remove both drive belts then unbolt the four bolts on the bottom pully. the double will then come off. remove the top and bottom timing covers in that order you will have to remove the water pump pully first. then mark your timing belt to ensure you get it back in time properly when reassembling. then loosen the timing belt tensenor pull timing belt off and let hang. then remove the water pump bolt then water pump. Install in reverse order. Make sure you clean the mating surface for the water pump.
Mar 16, 2009 | 1991 Mercury Capri
Sport & Outdoor - Others Logo
100 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
