Question about Pride New Mobility Legend 4 Wheel Scooter
I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
I HAVE A RASCAL MOBILITY SCOOTER IT HAS BRAND NEW BATTERYS BUT IT RUNS VERY SLOW IT IS ONLY GITTIG 9.3 VOLTS TO THE MOTOR BUT THERE IS 24 VOLTS OF THE BATTERYS I CHECKED ALL THE WIRES THEY ARE GOOD WHAT DO THING I SHOULD CHECK ????? THANKS FOR YOUR TIME BOB
  • Dan Hudson May 11, 2010
    There can be several reasons for this. When you are measuring the 9.3 volts, the batteries still read about 27 volts? Bstteries that read 24 volts are just about out of power.
  • 103 Answers
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Posted on Mar 09, 2009
Getting a 250 Rascal Motorized Scooter to run when battery indicator shows green. Is there a safety feature that we are unaware of?
If you leave the battery charger plug in the charging port the scooter will not move. If the disengagement lever is not engaged the motors will not run either.
Oct 13, 2016 | Health & Beauty
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
I have a rascal Lite way six it has new batteries but cuts out going up long hills.Has the motor got a thermal cut out. If I wait about 10 mins it starts going again.
hi, it could be battery power , are the new batteries now full charge ? there can be a thermal cutout on the controller mosfets getting tooo hot , and that can be faulty...
Questions to ask yourself, your weight , scooter capacity, condition of charger if batteries are new ...
Regards
Rob
www.facebook.com/gewizrepairs
Oct 23, 2014 | Drive Medical Health & Beauty
I have 18volts at the box that the battery leads go to and the consol leads go out of. the warning beeper goes off even when standing still and in neutral. i have tryed bridging the leads from battery to...
18 volts is not enough voltage to run this scooter. You have 2 batteries that should each read a max voltage of 13.5 volts each or 26 to 27 volts when fully charged and measured in series. 2 batteries that are 50% charged will read 24 volts. Your batteries are almost dead by this measuring method. Charge them up or replace them and your scooter should run. Hope this helps.
Feb 18, 2011 | Electric Mobility 4 Wheel Power Electric...
Batteries are fully charged. Scooter goes at full speed for approx. 1 block, then will slow to 1/2 speed and back up to full then back to 1/2. We have new batteries, checked for voltage at end of run, one...
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Jan 05, 2011 | Pride Mobility Products Celebrity X - 3...
Will not go. ohm wiring all good, batteries are good, checked fusses good, replaced throttle pot assembly, replaced controller.checked motor with 24 volts it works.got scooter to move by playing with...
me tool time you checked or changed about everything but did you check the electric brake. Sounds like the brake is not working or is working intermittentaly. The controller needs to get the right reading from the brake or the scooter will not go and when you release the throttle the brake should engage immediately. I can't give you a well thats the answer but you should at least ohm out the brake. If you can call rascal Company on Monday and ask for tech support they can give you what the reading should be Hope this helps
Sep 18, 2010 | Electric Mobility Health & Beauty
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
Electric mobility Rascal 265 LE scooter won't run 24 volts dc on batteries no sound or movement
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
May 02, 2009 | Electric Mobility Mobility Electric Power...
Pride New Mobility Legend 4 Wheel Scooter Logo
369 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
