LE fault code for LG WD-1019bd washer
Intermittent fault upon start of cycle. Will fill then drum wont turn to begin wash. Machine will "try" for about a minute then fault alert occurs and LE code is displayed. Has had new stator assy installed plus a sensor on the rear of the drum - all because of the same problem. At times will go through a number of washes without missing a beat. Will often perform faultlessly for the repair man and will often work for a month before stopping again. Last reapir man visit was 2 weeks ago. Worked up until today. Problem occurs on various wash programs. Will drain but not spin.
  • ysadgrov Dec 22, 2008
    Thankyou for that. The loose wires may explain why sometimes it works and sometimes it doesn't.
  • 17 Answers
Usually it is the stator at fault with an LE error. I would make sure the cable between the stators windings and hall sensor are ok back to the main control board also give the wires a good tug sometimes the copper breaks inside the wiring insulation at the white connection blocks. Check to make sure theres nothing got trapped inbetween the drum and tub this can lock the drum up and give the fault. After checking all the above i would think it would either be a faulty stator or the main control board has failed. Hope this helps.
Posted on Dec 22, 2008
2 Suggested Answers
matrixgent
SOURCE: LE fault code for LG WD-1019bd washer
I found that in winter time not a problem with my LG front loader, but when the temperature went over 30 Celsius the problem came back and intermittent like yours did, there was also an unusual noise coming from the machine.
What I did to fix the problem was to remove the stator and place it in the freezer for about half an hour or so, I also cleaned any minor dust and grit from both the Stator magnets and the Stator drum, replaced it still very cold and now it works well with no more unusual noise and the outside temperature has no more bearing on the machine not spinning this day!
I hope this helps!
Regard
Andre’
Posted on Dec 09, 2009
Bosch error E24 after 2 minutes into cycle, along with grinding noise.
Bearings or a belt have gone bad on the drum. After water fills and the agitator starts the drum begins to move and that's when you hear the grinding. error code stops the machine from further damage.
Jul 19, 2016 | Bosch Washing Machines
LE error on LG 2277HW
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
My washer is saying LE, what does LE mean? It stopped washing!
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Hope this helps.
Jun 29, 2011 | LG Washing Machines
Washer has a LE (or EE) code or something like that. First character looks like an E missing the top bar, or an L with an extra bar in the middle. i was doing a load of towels when this happened. i assumed...
Washing machine has an LE error code
Is this a new installation? In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Hope this helps.
Jun 09, 2011 | LG Washing Machines
Model wm2075cw trouble code LE (overload in motor) fills with water ,starts to agitate but wont spin when drum starts to turn it makes a low pitch squeal after a couple trys in different directions it...
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
NOTE: Make sure the drum is not overloaded
Thanks for using FixYa$%^
Feb 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does LE mean?
Nov 28, 2010 | LG WM-2277HW Front Load Washer
I keep getting a code le why?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
The washing machine starts ok and fills with water. However, it quickly begins to intermittently cut in and out whilst filling with water. It does this for a while before stopping completely. I've tried...
you did not mention the type of machine but for top loader the most probable cause of your issue is the door /lid switch that is in need of adjustment as most top loaders will fill with the lid open but cycle cant start or continue when the wash thinks the door is open this is a safety feature
Aug 14, 2010 | Washing Machines
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
548 people viewed this question
Top Washing Machines Experts
