Question about Frigidaire GLTF2940ES Front Load Washer
Wash tub seems loose and is really loud
Have Frigidaire front loading GLTR1670AS0
Started making noise, then on next load got really crazy load - banging. Wife stopped load and informed me. Let the fun begin!!:)
First thing I notices in the stainless wash tub is really loose. Can't say I examined it before, but I think it was pretty stable. Appears that whatever holds it in place broke..but I really have no clue. Just know I can put my hand in there and move it all over the place.
Took front bottom and back off washer and to my dismay realized that the tub itself is protected like Fort Knox. Getting in there will be ugly. Guru's do you know what happened here? Thanks!!!
We just had that same problem last week. My husband took off the back of the washer and at the bottom you will see a shock absorber on each side. One side of ours was broken. $35.00 later for the parts (you get two in a package) and the tub is sturdy once again. Husband said it was fairly easy to do. Hope this helps!
Posted on Dec 23, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
LG Front Load WM1815cs Makes loud noise when spinning. Inner tub is loose and seems to bounce making loud noise. Is this more than a bearing problem?
The outer tub and the bearing will need replacing as by replacing only the bearing will be a short lived repair as it will go the same way.
Aug 25, 2013 | LG WM1815CS Front Load Washer
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Starts Banging really ******* spin cycle, then quits... seems like the drum is loose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 12, 2011 | Frigidaire GLTR1670A Front Load Washer
It makes a loud noise when washing - it seems like the inner tub is sagging or something, when you open the door you can see the top rim of the tub. Is this fixable - and cost effective?
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 06, 2011 | Frigidaire FTF530FS Front Load Washer
The washer made a horrible noise and the tub seems to be loose from the machine. Can I fix it? The tub in my Frigidaire stacked washer all of a sudden with a fairly heavy load of jeans started making a...
you need to remove the agitator and check the bolts that hold the trunion to the shaft and make sure they are not broken.if one is just replace them make sure that the bracket is in the flat key way on the tub hope fully the tub seal is still good.
Oct 15, 2010 | Frigidaire FEX831CS Top Load Stacked...
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Loud thumping noise during spin.......not related to unbalance....manually turning the tub makes a loud noise.
Bearings shot or counter weights have come loose
Take the top off and check the weights first
Jan 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
247 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
