Question about Kenmore 63942 Dryer
Kenmore gas dryer model 110.76814690 will not heat up
  • djaklim Feb 08, 2009
    I used the electrical schematic and found the non resetable thermal fuse 196 degree with 2 blue wires going to the fuse did not have continuity, I bypassed the two blue wires to confirm the problem and the igniter fired up and the coils opened and then I had heat, Now to find a source for the Fuse....
    This in on the Kenmore Gas Model 741222
    Any help on sourcing the fuse?
  • Kenmore Master
  • 8,220 Answers
The bottom panel is held on by spring clips. Use a putty knife to access the bottom. The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse.kenmore gas dryer model 110.76814690 - 8f17134.jpg If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils NOTE: The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
My kenmore gas dryer model 110 will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 25, 2011 | Kenmore Dryers
Kenmore HE 3 gas dryer model 110.92822101 will not heat
heatman101
Sep 04, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite model #110700932990 dryer has no heat
My experience has been that most of the time when a gas dryer does not heat, that the igniter has gone bad...
The other less common problem is that the coils of the gas valve go bad...
Other problems can be the thermostat, the high limit, or the thermal fuse going bad...
Here is a tip that I wrote about not heat in gas dryers...
gas no heat tip....
heatman101
Nov 23, 2010 | Kenmore 74642 Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
Kenmore gas dryer no heat
Hi Steven  I hope this help U to fixya your dryer's problem
http://repair2000.com/norun.html
Was this helpful?
May 12, 2009 | Kenmore 73952 Gas Dryer
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Gas dryer will not heat
The dryer will not heat i check the vent to make sure no upstruction and open the back to make sure no wire was lose. where will the fuse be kenmore model 76722697 serial No. 0702383
Sep 13, 2007 | Kenmore 93042 Gas Dryer
Kenmore 63942 Dryer Logo
278 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
