Question about Saeco Magic Comfort Plus Espresso Machine
For saeco magic comfort plus, I can't purge it! the purge indication is always on even if i use the water, steem etc. what can i do ?
  • info189 Dec 21, 2008
    i have the same problem!
  • 2,039 Answers
In the kit of the machine they give a little pump if you dont have it use a turkey blaster the toll when you cook a turkey to put juice on it use that remove the water tank fill the blaster with water open side valve put pressure on the blaster put it in the hole where the water tank goes and apply as mush pressure as you can repeat it should vent itself if sign goes off refill water tank that it pierre
Posted on Jan 10, 2009
How do I ventilate my Saeco Magic Plus?
Open the steam/ hot water tap ie: run hot water through the steam wand.
Dec 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
How to ventilate Saeco Magic Comfort + coffe maker
Hi
If its a Magic Comfort + there is a water button on the panel (with the drop) that you push for water. You twist the dial for steam only.
If its a Magic Delux you twist the dial for water.
Nov 21, 2010 | Saeco Magic Comfort Plus Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
On my SAECO Comfort + machine, the ''Fill Water tank'' message does not go off even aftre the tank is filled.
make sure the magnet inside the water tank can move freely or float if it is then thr sensor inside is faulty
Nov 28, 2009 | Saeco Magic Comfort Plus Espresso Machine
My saeco magic comfort plus is spilling water out through the bottom of the machine. there is water in the little hole next to the brewing mechanism.
water from under the machine is almost always the boiler.
In some rare cases it is the flow meter.
Needs to be sent in for repair.
Aug 07, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus machine has message "Ventillate" how do you clear this?
open steam knob and water need start going on steam wand keep going couple minuts and you will see machine is ready,if you still have same problem thats mean your flowmetar is not good
Aug 03, 2009 | Saeco Magic Comfort Plus Espresso Machine
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
How old are your machine?
What number is the grinder on?
How often do descale the machine?
/Mirran
Aug 26, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
371 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
