Question about Sony VAIO VGN-S460 Notebook
VAIO Notebook Fn Keyboard not working
I just found out recently that my Fn key does not work. All the keys that i can use for sound, lighting, monitor, sleep and scr Lk cant be used. Didnt know what happened... Tnx!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Check under your "processes" in the Windows Taskmanager and see if you can find anything listed that starts with "hk" like "hkserv", "hksrv" or "hkcmd" .. That would be your hotkeys, if they were working. :) This means the driver for your hotkeys is missing or corrupt. Now, go to this site here: http://esupport.sony.com/perl/select-system.pl?PRODTYPE=24&NAVDISP=pc and enter all your info (like model number, ...), then you'll be able to download the proper hotkey driver for your model Vaio. write back if it worked. regards, Tom
Posted on Apr 06, 2007
The function key for the numbers on the keyboard i can't seem to stop it. When I want to use the letters i have to use the blue funtion key
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jun 27, 2014 | Acer Aspire One Netbook 8.9" Notebook
Keyboard default setting
This may be due to a numlock setting. Try holding down the Function key,it should be on the bottom left corner of your keyboard as "Fn", and press either Num Lock or Scr Lk.
The Num Lock and Scr Lk keys should be on the upper right hand side of the keyboard.
Feb 12, 2013 | Acer Aspire 7551-7422-22085
Number pad does not work
  1. Find Alt code.
    Numeric Alt codes for symbols are listed in Alt codes list. Check for Alt code of symbol you want to input.
  2. Enable Num Lk.
    You may need to simultaneously press ["FN" and "Scr Lk"] keys. That's the combination for "Num Lock" on some laptops. Look at the picture - the "Num Lk"/"Scr Lk" button is highlighted there.
  3. Hold down "Alt" key.
    Some laptops require you to hold both "Alt" and "FN" keys.
  4. Input Alt code of symbol on Keypad.
    Do this while holding "Alt" button pressed. Type Alt code on your laptop's numeric keypad. It's highlighted on the picture.
  5. Release all the keys.
    After you release all the keys alt symbol should be entered. If all this stuff didn't work - check if you have really enabled the "Num Lock" first. Remember that green indicator should shine near the lock symbol on your laptop's keyboard. If that wasn't the case - try simultaneously holding "FN" and "Alt" keys instead of just "Alt". That just might work.
Feb 15, 2012 | Toshiba Satellite P105-S9722 Notebook
For some reason the number lock is on my keyboard - i can*t figure out howto unlock it. i have to keep the fn key down in order to type the letters on the right hand side. how do i unlock/ thanks in...
Please follow the below instruction to fix your problem.
Press 2 keys at the same time: "FN" (next to the CTRL key, lower-left of the keyboard) and "num lk", which is the upper-right of the keyboard (it is on the same key as "scroll", and is next to "F12"). This will either turn on or turn off the "Num Lock" function. Both the "FN" and "num lk" are enclosed in a small rectangle. They are easy to see.
Hope the above information will be helpful to you. Thank you. Have a good day.
Aug 11, 2011 | Fujitsu Computers & Internet
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
How to use the Fn funktions on a ThinkPad T41
Each combination Fn-F1, Fn-F2, Fn-F3, etc. does some thing different.
Try and see what each does. For more details read your manual.
Good Luck
Sep 01, 2009 | IBM ThinkPad T41 Notebook
Key board problem
That is the 'FN' or 'fn' function that is sticking. Check the keyboard for debris. Carefully left the key marked 'fn' with a toothpick and make sure you don't have something stuck under it or use compressed air to blow the keyboard out.
Aug 23, 2009 | ASUS 90-A4C1K1000 Keyboard
Keyboard types T instead of £ when using Word 2007
hi i have an idea why, i hope it helps, try a combination of holding, pressing ,holding both, pressing both of the keys "Fn" and "NumLk" or "Scr Lk"
hope it helps, sorry if it doesnt
:P
Apr 30, 2009 | Logitech 967437-0403 Keyboard
Sony VAIO VGN-S460 Notebook Logo
708 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
