Question about GE Profile DPSB620GCWW Gas Dryer
Dryer beeps twice when you push start and doesn't start
Manual says incompatible dry, temp etx, but no matter what settings you use the machine beeps twice and does nothing
I had the same problem. Don't know if it will help you but, I closed the door and banged the door hard with the palm of my hand twice. A couple pennies fell out and it started without a problem!
Posted on Dec 22, 2008
I have a GE dryer model #DCVH660EH3BB, it powers on but when I press the start button it beeps twice at me and won't start the cycle. The lint trap and vent have both been thoroughly cleaned.
From the manual...
Cannot make a selection and the dryer beeps twice.
Possible Cause
The DRYNESS LEVEL, TEMP or OPTION that you are trying to select is incompatible with the chosen dry cycle.
Link to your manual, troubleshooting starts on page 24.
ShopYourWay GE Residential Dryer ShopYourWay
Jul 22, 2016 | GE Dryers
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
How do i do drying only
From the document I see, it is only a matter of pressing the "Dry" button. This is from the manual, available at and selecting the "Support" tab. On the right, there will be a "Washer/Dryer Combos Manual" link, which will download to your computer. Listed under "Dry" in Section 9 is the following.
• Drying options are easily selected with the Dry button. • For most even drying , make sure all articles in the clothes load are similar in material and thickness. • Do not overload dryer by stuffing too many articles into drum. Items must be able to tumble freely • If you open door and remove load before dryer has finished its cycle, remember to press the Start/Pause button. • By pressing the Dry button, you can select "Normal" - "More" - "Time" - "Off" - "Low Temp" - "Less" • Your dryer can handle a load of up to 9 lbs. (4 kg) dry weight of articles. • When drying cycle is completed, [Cd] (Cool Down) is displayed on the Multi display. • Cool Down is set automatically when the drying cycle is complete. • If clothes are not removed promptly when the drying cycle ends, wrinkles can form. • The Cool Down feature periodically tumbles, rearranges and fluffs the load to avoid wrinkles for up to 4 hours. • The message [Cd] will continue to display until the clothes are removed or the Start/Pause button is pressed
Hope this solves your problem. I highly recommend downloading the users manual, it is a wealth of information and will prove useful in many circumstances.
Please rate and comment Thank You Joe
Sep 06, 2011 | LG WM3431 Front Load Washer / Dryer
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
I bought a used etx90 with autostar. The scope works with the basic controler. When I plug in the autostar it beeps & lights up the number panels, but I can't see anything in the led screen. is...
The contrast and brightness can be reset --- here is the manual -- how to do this is listed in the manual. If this does not repair the controller then you will need to buy a new hand controller-- the 497 hand controller is available used on Ebay from time to time.
Manual down load above--
May 06, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
Aprilaire manual humcontrol 4655 hum 560 .when control clicks works fine.move dial to outside temp never works changed 4655 twice i have 28\r\nvolts ac all the time
When humidistat is at ouside temperature that may be a lower humidity setting than is in your home. Doesn't sound like there is a problem. If it is too dry in home you can set it above ouside temp to turn on. The ouside temp setting is estimate that you will not get condensation on windows.
Jan 17, 2011 | Aprilaire 550 Humidifier
Machine in cold shed. Supply pipes no longer frozen, but machine still displays F37 error and beeps and no water getting in. Have tried presssing temp button twice but no good.
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 09, 2010 | Washing Machines
GE Profile DPSB620GCWW Gas Dryer Logo
446 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
