Question about Dryers
GE dryer problem
GE frontload dryer dcvh515gfoww. Clothes started getting caught in door gasket/seal? Now we get a loud sqeuaking/scraping sound coming from the top of the door.
  • Anonymous Feb 22, 2009
    I have the same problem... I noticed a piece of plastic bracket poking from behind the seal, we are going to take the cover off today and see what is behind it. My guess is that whatever was holding those brackets in is scraping the drum, could be screws or something. I will post again later...
  • Anonymous Mar 28, 2009
    My seal is broke... Where do i get a new seal
SOURCE: Squeaky Dryer
Master_Tech:
I have the same model number and the same squeaky problem. I could use the same fix that you gave bebowser.
thanks
skuterbum@yahoo.com
Posted on Apr 16, 2008
Illeagle
  • 525 Answers
SOURCE: ge dsxh43
This link goes directly to the exploded view/tear down page for G.E. dryers at Repairclinic.com. From there you can navigate back to the parts breakdown/order page. Just enter your model no. in the search box and click search Most G.E. dryers have 3 or 4 screws holding the top panel to the front panel. Open the door andd they should be accessible at the top of the door opening. After removing those, then should be 2 screws at the bottom to loosen, then the front lifts off the 2 screws. The diagram should help guide you through the rest.
http://www.repairclinic.com/0100_20.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 08, 2008
SearsTechToo
  • 261 Answers
SOURCE: Replace felt seal on gas dryer door
Yuck, nothing like replacing the felt, removers will only give you brain damage.I would find something hard plastic to scrap it off to prevent scraping of the finish. Dont give up a burn it off, I know from experience. Try the red plastic scrapers from Ace Hardware, there cheap by a dozen just in case the person who installed the felt had a seizure with the glue!
Posted on Sep 16, 2008
SOURCE: My clothes are getting caught in my dryer.
I am having this same problem with my GE dryer. I found a post on fixitnow.com from a guy that has repaired these for years. He says it is the rear drum bearing. Looks like a pretty easy fix, I am going to try to do it myself. If you try this, I have also read that you should spend the extra $10 to go ahead and replace the drums front felt glide kit.
http://fixitnow.com/2005/03/field-notes-frigidaire-dryer-front.htm
Good Luck!
Posted on Mar 25, 2009
pumpkinman
  • 1147 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
Clothes get caught and burnt around the outer edge...its GE dryer
There is uasually a felt gasket around the ends of the dryer tub.
if it is missing clothes could get caught.
Sep 23, 2011 | Dryers
My clothes are being ruined in the dryer..I have the DCVH515 frontload model...clothes getting caught inside..i think some kind of seal from the inside around the door opening is gone..clothes are getting...
I have had the same problem for about 6 months. I have been sticking duct tape on the inside over where my clothes were getting hung/caught. It works :) but the heat makes the duct tape peel off so you have to keep replacing it. We finally had to call a repairman when the drum started making a horrible noise. He came out this morning and said one of the "sliders" the drum rolls on had broken. He said when the sliders begin cracking it can make a very slight gap where the clothes were getting caught. I have run 3 loads this morning and had only one dishtowel get hung whereas before multiple items in each load were doing it. He said there are multiple sliders so it may happen again.
He also said the clothes getting hung was an indication of a breaking slider so you may want to call a repairman to head off your drum doing what mine did. It cost me a total of $105 and I live in SE Texas.
Aug 02, 2011 | GE DCVH515EFWW Electric Dryer
Loud noise and clothes stuck in dryer drum
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS It sounds like you have two problems. #1 Problem...Noisy rollers #2 Problem...Faulty front door felt seal, causing the clothes to get caught.
Sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor and door seal. You can now inspect/repair/replace the felt door seal. Now is also a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 21, 2009 | GE DBSR453EBWW Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Squeaking and clothes get caught in door
Your problem sounds like drum rollers is in need of lubrication.
Remove the front of the dryer. This will expose the drum,belt, and front seal. Remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
If your front seal is bad, it will cause clothes to be caught, replace it if it is needed, or reinstall if it has come out of place.
Good Luck,
I hope this helps
Oct 20, 2009 | GE DBXR463EBWW Electric Dryer
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Scraping/high pitched noise in GE model DCVH515GFOWW.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
Dryers Logo
93 people viewed this question
Top Dryers Experts
