Check the gasket fist if it's ok check the closure.there's a door closure on the bottom of the door and hinge that wears out and needs to be replaced,is the fridge door when closed side by side lower than the freezer door?it's plastic,here's a picture
http://www.repairclinic.com/PartDetail/Closing-Cam/R0181181/1035
part number R0181181 but call your local parts store and give them your model and p number or manufactures number and they will sell you the correct part,on some kits they give you the cams,shims and new screws,as for the drip pan overflowing,this is most likely from the warm air getting into the fridge melting out the frost on the coil or ice,usually when this happens the air ducts freeze up and the fridge section gets warm because the dold air from the freezer can't blow over into the fridge side because the air ducts are filled with ice,shut down the machine or unplug it,remove everything from the door,remove the top screws and then tilt out the door and lift up,put the door on it's side and change out the cams,it's usually a 5/16 inch screw holding them in place and then put it back together,while you have the door out check the gasket,any rips or anything change it out.hope this helps and good luck.
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
