Question about Saeco Classico Espresso Machine
How can I adjust my boiler ? the water is only at 140 degres
How can I adjust my boiler ? the water is only at 140 degres and my coffee is not enought hot
    Sergeant:
  • Saeco Expert
  • 223 Answers
The thermostat may have gone bad on your espresso machine.
Saeco parts and cleaning supplies:
www.CeriniCoffee.com
Posted on May 29, 2008
Mcdonnell Miller automatic feed valve does not seem to supply enough water for steam boiler. Is there an adjustment?
Steam Boiler Water Feeder Valve Repair FAQs
inspectapedia.com/heat/Steam_Boiler_Water_Feeder_FAQs.php
It does not say, what causes high level of water in the steam boiler. ... High pH in your water supply can cause foaming and water feeder troubles; .... I have a clearenough understanding of the condition of your water feed valve .... My system has separate McDonnell and Miller automatic water feeder and Low water cut off.
Steam boiler Automatic & Manual Water Feeder Valves
Dec 21, 2015 | Coffee Makers & Espresso Machines
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
I need to turn the temperature down on my Hydrotherm oil-fired burner. How do I do that?
On the front of the unit on the upper right is a grey box. Remove cover. Inside there should be a notched steel dial to adjust the water temperature.
Hope this helps.
Bob
Mar 04, 2014 | Hydrotherm Boiler, Oil Fired - PB-105/120W
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
I own the Ikon BES400XL and the coffee does not seem hot enough. Temperature on turning it on is 140 and gets to 160 if I let it warm up. Shouldn't it be around 200F? What gives? Is it something I can...
It was set to that temp by the factory, check the thermostats on the boiler of the machine, those are the set temps. If your machine has a pressure stat you might be able to adjust it to a little higher, never go past 198.
Aug 10, 2010 | Breville BES400 Espresso Machine
Boiler not keeping pressure
mostly your boiler gasket is gone, or a line has blown might be lucky with a leaky o-ring
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
I have a quite old la pavoni p3v2 110v 2000w two group machine that I have just finished a rebuild on. The machine goes to full temp on the boiler, the steam is great, but I can't get more than about 140...
Check the top of the group head there is a large bolt, within that is the metering jet and filter, that might be the cause of the blockage(either the jet is clogged or the filter is clogged). As for the full temp on the boiler what reading do you get on the gauge boiler side, it needs to be at about 1.2 bars.
Jun 21, 2009 | Rancilio Silvia Espresso Machine
Think Pump or boiler broken as water doesn't flow through
If you cannot get hot water from machine(brew unit or steam valve), then there is something wrong with boiler elements.
If water won't flow thru coffee(pump is not vibrating) and you've tried adjusting the grind to a coarser setting, then you will have to replace the pump($50).
However, since no water is going thru machine and it does not heat up then the problem might be the board or the inline fuse on the machine.
May 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Francis X1 overheat quickly
hey. you have calcium build up on the wands that go in your boiler so they can't messure the temp properly so it keeps heating.buy a decalcifier from any coffee site online or coffee machine sales and repaires place.
Dec 14, 2008 | FrancisFrancis! X1 - Stainless Steel...
Saeco Classico Espresso Machine Logo
127 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
