Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
I do have i mdb file on 1 pc and i need to shared wit 3 pc
There is small network
  • 69 Answers
First make sure all 3 PCs are on the same workgroup or domain. You can verify that in the System Properties, accessible by right-clicking the My Computer icon and selecting Properties, then selecting the Computer Name tab; below the Full Computer Name will be the domain or workgroup.
Once all 3 PCs are on the correct workgroup/domain, navigate to the folder where the file in question resides, and right-click the folder itself (not the file) and select Properties, and then the Sharing tab. From this tab you can select to share the folder, and set access restrictions if needed, and then the other 2 PCs should see the new share in their Network Places within a few minutes.
Posted on Dec 23, 2008
Need guidance to restore mdb file from Access
Here is a link http://www.en.accessrecovery.org and http://www.compactaccessdatabase.net on the same particular problem that I resolved effectively using this tool. This tool is smartly programmed and allow to restore database from a corrupt database table without hassle.
Apr 11, 2014 | Computers & Internet
Tip
How To Enable File And Printer Sharing In XP, Vista, and 7
Verify File and Printer Sharing for Microsoft Networks is Installed by following these instructions for your particular OS:
Windows XP
1. Log in as the administrator or as an account that has administrator capabilities.
2. Open the Control Panel and click Network And Internet Connections.
3. Below "Pick A Control Panel" Icon, click "Network Setup Wizard."
4. On the Welcome screen that displays, click Next and then click Next again. The wizard displays the Select A Connection Method dialog box.
5. If your host computer connects to the Internet through a residential gateway like a router, access point, or base station, select the second option and click Next.
6. The following prompt is for your computer’s description and name. Accept the default answers and click Next. Do the same for the Workgroup Name prompt.
7. On the File And Printer Sharing screen, select the Turn On File And Printer Sharing radio button and click Next.
8. When the process is complete, the You’re Almost Done dialog box displays.
9. Select Just Finish The Wizard; I Don’t Need To Run The Wizard On Other Computers and click Next.
Windows Vista
1. Click Start, right-click Network, and then click Properties.
2. In the Network and Sharing Center window, under Sharing and Discovery, click the down arrow next to File sharing.
3. Within the File sharing settings, click Turn on file sharing, and then click Apply.
4. Next, click the down arrow next to Printer sharing.
5. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
Windows 7
1. Click Start, open up Control Panel, then click on Network and Internet, then click on Network and Sharing Center.
2. In the Network and Sharing Center window, click on Change advanced sharing settings.
3. In the Advanced Sharing Settings window, you will need to change the settings for the Home or Work, and Public profiles.
4. Turn on File and Printer Sharing for both Home or Work, and Public profiles.
5. Click Save Changes and close this window.
on Jul 14, 2010 | Computers & Internet
Does not seem to print xps files.
For sure, you're trying to print a document or text from a client PC in which the print network was not shared. If this was the case you can try these simple 1-2-3 steps:
1. In the server make sure that the printer is shared through network thru the Printer and Fax Config in the Start Menu
> Select Printer
> Properties
> Sharing
> Share this printer (Printer name ex.: Brother...)
> OK
2. In the client PC make sure that the printer is joined through the network thru the Printer and Fax Config in the Start Menu
> Add A Printer
> A Network Printer
> Connect to the Printer (ex.: \\server\Brother...) Automatic Detection...
> Next.....
> OK
3. Ready to print any files....
Jun 16, 2011 | Brother DCP 165C Compact Color Inkjet...
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Can't Share Files/Folders over home network
That sounds more like the security settings on the pc are not set correctly. Should be nothing to do with the card or the laptop. This is just a windoze thing.
Share a drive or folder on the network To share a drive or folder on the network
  1. Open shortcutcold.gifWindows Explorer, and then locate the drive or folder you want to share.
  2. Right-click the drive or folder, and then click Sharing and Security.
    • If you are sharing a drive, on the Sharing tab, click If you understand the risk but still want to share the root of the drive, click here.
    • If you are sharing a folder, go to the next step.
  3. Do one of the following:
    • If the Share this folder on the network check box is available, select the check box.
    • If the Share this folder on the network check box is not available, this computer is not on a network. If you would like to set up a home or small office network, click the Network Setup Wizard link and follow the instructions to turn on file sharing. Once file sharing is enabled, begin this procedure again.
note.gif Notes
  • To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer.
  • When you share a drive or folder, anyone who has user access to the network can read the contents of that drive or folder. If you want to remove the drive or folder from the network, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, clear the Share this folder on the network check box.
  • To allow complete access to the contents of your shared drive or folder, follow steps 1 and 2 above to get to the Sharing tab. On the Sharing tab, in Network sharing and security, select the Allow network users to change my files check box.
  • To change the name of your folder on the network, in the Share name text box, type a new name for your folder. This will not change the name of the folder on your computer.
  • If you are logged on as a guest (a guest account provides access to the computer for any user who does not have a user account on the computer), you cannot create a shared folder.
  • The Sharing option is not available for the Documents and Settings, Program Files, and WINDOWS system folders. In addition, you cannot share folders in other user's profiles.
Apr 05, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
How to password protect .mdb, just one table alone.
1. open access. 2. From file menu select open => select the location of .mdb file and while selecting open option you notice a small triangle. Click that triangle and select open exclusive. after file opening go to database tools and select set database password. give the password and save it. Thats the procedure
Apr 03, 2010 | Microsoft Access 2003 for PC
Create access mdb file by vfp code
Try this
#define dbLogical 1
#define dbNumber 2
#define dbInteger 3
#define dbLongInteger 4
#define dbCurrency 5
#define dbSingle 6
#define dbDouble 7
#define dbDateTime 8
#define dbBinary 9
#define dbText 10
#define dbOLEObject 11
#define dbMemo 12
#define dbReplication 15
#define dbDecimal 16
if file("C:\accesstest.mdb")
delete file c:\accesstest.mdb
endif
public oAccess
oAccess = createobject("Access.application")
oAccess.visible= .t.
newMDB = oAccess.NewCurrentDatabase("C:\accesstest")
newtable = oAccess.CurrentDb.CreateTableDef('testtable')
with newtable
.fields.append(.CreateField("Field1", dbLogical))
.fields.append(.CreateField("Field2", dbNumber))
.fields.append(.CreateField("Field3", dbInteger))
endwith
oAccess.CurrentDb.TableDefs.append( newtable)
dbc2Convert = "\\tpdfiles\data\dfreeman\tip\data\rta\rta"
open database (dbc2convert)
dbgetprop(rta,"table",)
After it runs you will need to close the MDB and reopen it.
Oct 15, 2008 | Microsoft Computers & Internet
Setting up a new computer on a wireless network
hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click Start, right-click Network, click Properties.
-The Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click Customize.
3. In the Set Network Location dialog box, click Private, and then click Next.
4. In the Successfully set network settings dialog box, click Close
By changing your network location type to private, network discovery is automatically enabled in the Sharing and Discovery section of the Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
  • File sharing
  • Public folder sharing
  • Printer sharing
  • Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
  • Locate other computers and devices on your home network and have other computers locate your computer
  • Share its folders
  • Share its Public folder
  • Share its printers
  • Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
  2. Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
  2. Within the Public folder sharing settings, click one of the following:
    • If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    • If you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
  3. Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
  2. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
  2. Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
Feb 14, 2008 | Computers & Internet
Microsoft JET Database Engine error '80040e09'
This worked for me in a similar situation; make a copy of the .mdb file in the same folder. Delete the original .mdb file and rename the copy with the name you used for the original. This should get rid of the read-only aspect. Good luck.
Aug 29, 2007 | Microsoft Office Standard for PC
Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
