Question about Fisher Paykel EcoSmart GWL15
Bad order during final rinse
We have a top loading fisher paykel intuitive eco washer and this problem just started happening that during the final rinse there is a bad odor. We have taken it apart and there is no residue build up or mold on any parts we can see. Also did a fosforus rinse to clean it out internally, but it still is happening? We do about 2-4 loads a week, mostly cold in the past and it is about 1.5 yrs old. Any help would be great
-Jeanette
  • eli3 Dec 26, 2008
    Yes Guru, we also did all that and found nothing notable. Is it possible that the water is getting pumped out at such a velocity (with the high spin cycle) that septic gases are escaping the u-pipe? The smell only occurs on the final spin cycle. The washer empties the tub for the first rinse after the main wash and there is no smell there, nor is there a 1000rpm spin cycle. Hmmm
  • jcsaws Dec 28, 2008
    MY wife noticed Burnt smell at the end of the cycle(my nose isn't as good) iv'e taken the top off . the inner tub and agitator off like you told Jc52 ,yes it's grotty as i'm a mechanic. i found what looks like a lite metal strip on around shaft before i pulled out the tube. The shaft has a very small amount of movement and the seal seems ok. Is there any I.P.L 's for the 703 around. thanks in advance
    The pump seems ok and not leeking for a change. this old girl get a lot of work. cheers JC
  • 145 Answers
Hi Jeanette! Welcome to FixYA!
When you say "We took it apart" are you talking about removing the inner basket or just the agitator/rinse dispenser?
On the Fisher-Paykel washer I have worked on in the past where the customer complains of odors, I will remove the inner basket (Wash tub) and if possible take it outdoors and spray it down with a hose. The outside edges of the basket (the side that you cannot see from the clothes side) sometimes gets a murky buildup on it. Also the underside of the basket can get pretty grungy as well. There are some pockets underneath the tub that can hold scummy buildup and it will all wash off with a garden hose sprayer. Now up here in the Great White North, this is not an option (It's around 15 below zero here) but perhaps where you live it is not as cold. It is really not that difficult to pull the inner tub out of the washer. You pop the white plastic covers off the screws that secure the washer lid to the cabinet, remove the screws and the top of the washer lifts right up. You can un-snap the collar that runs around the top of the tub (no tools required, just pop the tans and pull the ring off to the side, just be careful of the little balance spring in the left-front corner) I usually just leave the spring attached and gently set the collar down the left side between the outer tub and the washer cabinet. Now take pop the rinse dispenser up and out of the center of the agitator and unscrew the plastic wing nut that secures the agitator in place ans pull the agitator out. Now that entire inner basket just lifts right up and out of the machine. It's a little on the heavy side, so you might need a helper. Once you lift it out, now you can not only rinse the basket off, you can also grab a rag and wipe down the outer tub, as it will probably have some deposits on it also. Since it is plastic, they will wipe right off.
This may sound complex but it really isn't. Fisher Paykels are very well designed as far as ease of service. That tun comes out basically with nothing more than a screwdriver.
I hope this helps you. If you need more info, please ask. If you feel that I have not been helpful, please allow me the chance to redeem myself before you rate my answer!
Thanks for the opportunity to help you and Happy Holidays!!!
Posted on Dec 22, 2008
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive Eco switching itself off during cycle.
Could be a bad drain pump or controller or rotor position sensor. You will need a Tech to take a look. Unfortunately with these machines there can be many reasons for a failure. Call F/P to get a certified technician out there.
Jun 14, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
the top load f/p washer is a "high efficiency" unit and has to be used with "HE" type soap. it is a non-sudsing soap and if you are using low or regular soap then the residues are not rinsing out causing the odors. they do make a special cleaning tablet called "affresh" it is designed to clean out any residues caused by your using too much or the wrong type of soap.
you can also run a cup of bleach on the longest cycle with hot water and see if thats helps too.
Dec 28, 2008 | Fisher and Paykel GWL11 Top Load Washer
Hi,Is the machine connected to a stand pipe or sink connection?
Dec 28, 2008 | Washing Machines
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
178 people viewed this question
Top Fisher Washing Machines Experts
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
