Question about LG Studioworks 563N 15" CRT Monitor
I am unable to make resolution 1024 x 768 in lg model 500G
Please help me what to do as I am unable to change resolution as mentioned above my monitor is LG studioworks 500G. Should I install the driver for the monitor ? Please give me guidance from where I can download the drivers for the monitor if need to do so.
  • 528 Answers
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Posted on Jul 30, 2009
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Where is vertical ic in lg 500G studio work crt monitor
Hi, i need help here about LG Studiowork crt monitor (500g). Unlucky, my monitor dead suddenly when i do surfing internet.
So, I had to check and found that there is a defective component (explode).
I tried to google the serial component "YZ010G", but no details.
Please friends help me. thank you
Jan 17, 2013 | Computers & Internet
NOT SHOWS RESOLUTION 1360 by 768 IN 16" WIDE LG LCD MONITOR MY MOTHER BOARD IS GIGABYT INTEL CHIPSET 865, PLS GUIDE US
Hi!
Installing the video card driver can make use of its features of higher resolution support for your LCD monitor.
And also install the driver of your LCD monitor. This enable to use higher resolution that could provide with your computer video card as I have mentioned above.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 05, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
Resolution Problem
go to your desktop display properties then go to setting then go to advance then monitor tab chack your screen refesh rate may be 85Hertz.now change rate to 56Hertz and apply.now you change your resolution 800*600 to 1024*768.
Dec 20, 2008 | LG L1915S 19" LCD Monitor
Can't change resolution on older monitor M50
It seams your video card is not properly install. If you have more option greater then 640*800 then it means your monitor not support above resolution that you mention.
If problem is not this which I mention then please reply to this thread with explanation.
Nov 20, 2008 | HP Computers & Internet
Not working 1024 by 768 pixels resolution
reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
Nov 13, 2008 | LG Studioworks 440SI 14" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
220 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
