Question about Maytag EPIC MFW9600S
How do I reverse the door on Maytag Washer
How do I reverse the door on a maytag epic 9700 front load washer so that it swings the opposte direction??
SOURCE: Need to replace my Maytag the door is reverseable. Who makes those now?
The doors are reversabe they go from left hand open to right hand open. Just reverse the hinges, put the door fillers ( triangle shape go toward the front. Remove the plug put it in the other sidel. Now take the metal door strke and put it on the other side, Then take the filler from on side and put it on the other side. Takes 10 to 15 minutes to make the change.
No need to purchase another door!
Posted on Apr 25, 2009
  • 901 Answers
SOURCE: can u change the door direction on a maytag washer
It is possible with little drilling work on the body. But it requires skill and patience. Wirings to the door lock has to be re-routed etc. It is not worth the trouble!!
Posted on Apr 06, 2010
rylee_smith
  • 8619 Answers
SOURCE: what does the error code Sd mean on my Maytag Epic
Hi
Thanks for using FixYa. Error 5d/Sd means too much detergent was used. Try the following procedure---
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please accept the solution if the issue is resolved post a comment for further assistance.
Thanks
Rylee
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Maytag Epic z washer will not start just flashed
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$
Posted on Sep 28, 2010
SOURCE: Maytag Epic Z Front Load
The error code is not 5 D it is "S" as in Sierra D. The letters stand for Slow Drain.
I had this code and it was fixed in 10 minutes or less.
Simply remove the bottom panel from the front of the washer. You do this by removing the three screws at the very bottom of the front panel. There is a screw on the bottom left, bottom right, and bottom middle.
Once the screws are removed the front panel should drop down slightly, and then you can remove the front panel.
On my peticular model the drain pump had a very large circular tube with what looks like a twist off handle in the middle.
On mine, you rotate the handle counter-clockwise. It's very stiff at first. This is because of the thick rubber seal that you are rotating against.
After about one complete spin it should get very easy to spin and you unscrew it completely off, and pull straight out.
On mine, the back of the tube you pull out contains a tray that hold junk coming out of the wash.
The tray has holes for water to pass through to get to the pump.
When I took mine out, there was one quarter, and one nickel in the tray. That was all it took to clog the dain holes so the drain water moved too slow.
The on-board computer measures the water flow and can tell if it is moving too slow.
Keep in mind, sometimes the money in the tray must have vibrated off to the side just enough that the drain flow was fine.
My error code would be there one day, and not reappear for about two days. Then it would come back every day for about 3 or 4 days in a row.
It was very irratic to pin down when the code would appear, and when the wash would be fine.
I cleaned out the money and some very minor lint and re-assembled.
Posted on Oct 14, 2010
The washer door is locked and will not open
Problem with Maytag MHWE450WW front load Maytag washer. The washer door is locked and will not open. I tried several suggestions in the manual, but none work. Please help!!! My email address is
hummingbird54@verizon.net and my name is Antoinette Roy
Oct 10, 2012 | Maytag EPIC MFW9700S Front Load Washer
Can u change the door direction on a maytag washer
Apr 05, 2010 | Maytag EPIC MFW9700S Front Load Washer
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
How do you reverse swing on door
Ity is not normlly possible to reverse the door on automatic washers, as they are not configured for this.
Tthankyou.
Dec 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
MFS9700S Maytag washer Can the door be reversed??
not on washer as far as i know . just dryers but just look in your book or call the store you got it at
Feb 21, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9600S Logo
331 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
