Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Remove the cover and check whether the air filters blocked with dust.
Whenair filters are blocked, air doesn't
flow freely through the projector. This result in overheating, leading to
automatic shutdown.
When this happens, air doesn't
flow freely through the projector and result in overheating, which leads to
automatic shutdown.
