Question about Hitachi 50UX57B 50" Rear Projection Television
Shrinking screen We have been having problems with the screen shrinking from top to bottom on our projection tv. It sometimes corrects itself after being on for a while, but also goes back to smaller screen at times. What could be wrong. We had cable company come out, but they found nothing wrong with hookup. Please help.
    Genius:
  • 1,074 Answers
The tv is having a vertical problem have a tech look at it for possible repair.the problem is intermittent therefore it could be that it has cold solder or the vertical ic needs to be replaced along with spme caps that are not filtering the voltage properly,good luck.
Posted on Apr 06, 2007
Magnavox 52" widescreen tv year of model 2003
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Magnavox rear projectio9p6031c103 The picture quality is terrible
Hope this helps,
Dec 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
How to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
Oct 03, 2008 | Philips 60P8341 60" Rear Projection...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
60" Projection - Screen shrinks down then back up
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 19, 2008 | Philips Magnavox 55P9271 55" Rear...
Phillips 51pw9363 51in
Oct 25, 2007 | Philips 9P6040C 60" Rear Projection...
Screen shrinking
You have bad solder connections on the vertical output IC or on one or more of the surrounding components. Good Luck
Jul 21, 2007 | Toshiba 36A40 36" TV
Hitachi 50UX57B 50" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
