Question about GE JKP27 Electric Double Oven
Probe and sensors sticking too far out
In both top and bottom oven a probe is sticking out from the back wall. Is this normal? I can't remember if it was there before.
In the bottom oven, there is long probe type thing that seems to be loose and it gets in the way when I use the oven.
I am having trouble removing the bottom oven door so I can clean the oven. Is there a knack to it.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 269 Answers
Yes the probes can stick out from the back oven walls. They look like thin pencils about 6" long. They should NOT be loose. The probes are your temperature sensors. If they become damaged your oven may not work. The probes are generally high up on the wall and to one side...about an inch or so down from the top...and the same from the side. They should be horizontal and not bent at an angle. Some probes run along the side of the oven wall and do not protrude into the baking area. In general the probes (whatever type) should not really interfere with the baking zone
Posted on Oct 21, 2017
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
Master_Tech
  • 770 Answers
SOURCE: how do I replace the probe
Yes and no the reason they ask you to cut them is the lenght of the wire does affect some of the probes (thermistor) it reads resistence and the longer the wire the more it will read if you want it to be for sure your model is this type do it the right way and pull the oven if you want to cut it in place then try the oven like that if you are happy with the temps then leave it the reason the wire wont pull out the is a zip strap holding it in the wire bundle behind the back wall.Hope this helps
Posted on Jan 21, 2008
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
  • 10865 Answers
SOURCE: Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Posted on Aug 17, 2009
Ra610 thermostat
is easy the probe inside the oven is helt there by two clips,remove back off oven after turning off the power to it pull off knob undo nut with long nose pliers and remove change wires over one by one so they are connected right pull out old probe push new probe in though the back to the inside of oven and clip into place
Nov 07, 2013 | Fisher and Paykel Ovens
Receiving a F 10 message
F10 error code means "runaway temperature condition"
If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor and control checked.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven. Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven. Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms. The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website.
Hope this helps.
Apr 25, 2011 | Kenmore 47833 Electric Single Oven
F2 and a beeping noise just replaced the 350 degree sign on my oven as I was baking supper. What's up?
This is a fault code for the oven temperature sensor.
The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. If the resistance is bad, replacing the oven temperature sensor probe. This part can be purchased at www.appliancehelponline.com
Mar 23, 2010 | Kenmore Ovens
I have an in wall oven and it is beeping and showing f10
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^&^y
Feb 11, 2010 | Kenmore 30169 Electric Single Oven
F10 fault on tappan range model tef351ewd
Sep 20, 2009 | Tappan 30IN ELEC IGNa Oven
Code F10
Sep 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Recieving a F10 message
Jun 27, 2009 | Kenmore 47782 / 47784 / 47789 Electric...
The oven keeps beeping and giving a code of F10
Dec 14, 2008 | Kenmore 47783 Electric Single Oven
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F30 - F10 error messages
Jul 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
55 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
