Question about Logitech V20 Computer Speakers
USB Audio Device Drive Load Failure
For a couple of years, I haven't had this problem. Then it was sporadic. Now it's repeatable.
V-20s connected to laptop.
Everything works fine.
Reboot computer.
USB Audio Driver fails to load.
Disconnect V-20s.
Reboot computer
USB Audio Driver loads.
Plug in V-20s.
USB Audio Driver.
Driver date 7/1/2001
Driver version: 5.1.2535.0
Should I update my driver.?
  • dhecht Dec 21, 2008
    Windows XP Service Pack 3.
  • Anonymous Apr 10, 2009
    My V20 notebook speakers no longer work. I am using a Dell Latitude D810.
    President:
  • 1,179 Answers
Driver probably needs update. I had this problem using my usb speakers until updating driver to newest version.
Posted on Dec 21, 2008
Cakewalk v20. lost connection to the device during recording. used it successfully for approx 1 year. nothing new connected at the time of failure. tried new usb cord and different computer. v20 will not...
Check that in the control panel of Windows, "Sounds and devices" your interface is the default device in each of the panels under the tabs such as "Voice" and the others.
May 03, 2011 | Cakewalk VStudio 20 Audio Interface USB
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
I have a Digital Trio Viewer and the software will no auto load. I have charged the device for a couple of hours.
Is your system XP? If so, try this, disconnect the device once it is charged for whatever length of time, then connect it again, your computer should then find the unit as an external drive and launch the application to load the pictures. If this does not work, disconnect the device, shutdown the computer then connect the unit before starting the computer so it will recognize the unit at bios startup, then go to the drive represented by the digital trio viewer and launch the application. Good luck. P.S. If everything else fails call the 800#.
Dec 25, 2009 | Electronics - Others
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
My computer does not recognizing Sony erricson w580i's usb port.
did you download the disk the phone came with ...
or you could have damaged it such as running over it with a chair.. that could be why if you haven downloaded the disk you should..
Apr 27, 2009 | Sony Ericsson w580i Cellular Phone
My maxtor 200GB drive is not recognized by my CPU anymore!
Hi Crkinard.. i think you shuld first find out whether the problem is with the external device or your computer... so check if the device is recognised by another system... as you have been using the device dor couple of years i think yours computer's drive for external devices should have been corupted.. so check out the device with some other computer.. if it is recognised in that computert then you can easily reinstalled the software for your device again..
Oct 13, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
USB Connections
when you put a device on the usb slot the system will detect and check what is the device then after it identifies the device it will load the necessary drivers for it. it is possible that the system is loading a corrupt driver to drive the usb device resulting to a system halt. it could be a driver related in storage devices such as thumb drives that is causing the problem.
try to update the usb drivers using the update driver option on your device manager on usb controller.
Sep 14, 2008 | ASUS P4PE Motherboard
Failed to Load Files
I was able to access the play list using Windows Media Player. I was trying to get the computer to recognize the player, and it wouldn't do it. I even downloaded the Lyra Personal Audio Player updater... that didn't work or recognize the player.
Try the programs that are on your computer for playing MP3's.
Jun 12, 2006 | RCA Lyra RD2854 40 GB MP3 Player
Logitech V20 Computer Speakers Logo
646 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
