Question about Dacor Preference SGM466 Gas Cooktop
Some Burners Will Not Ignite
I have a six-burner gas stove top. A couple of burners will not ingnite without a match. The igniter clicks but no spark. The two burners are: left back and middle front (knobs on the right hand side). I have tried adjusting the "caps" and wiping down the "teeth" in each burner. Occassionally this helps, but it could be just a coincidence.
  • Anonymous Mar 17, 2014
    How can I get the burners to ignite once again?
    President:
  • 1,462 Answers
Probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Posted on Apr 06, 2007
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
ELECTRONIG IGNITION DOES NOT WORK TO IGNITE THE COOKTOP I HAVE TO USE MATCHES TO IGNITE THE GAS
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 04, 2011 | Bosch 30 in. NGP74 Gas Cooktop
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
One burner won't ignite. The electode was
Most likely its dirty meaning the burners themselves and aren't getting any gas through. If you feel lucky you can do this without turning off or unplugging the stove, but on the oft chance there is a short I would do those just to be on the safe side. If you know how lift the top part of the stove up, you did not give model number. Find the electrode and clean with a clean toothbrush, plug in see if there is a sparks, actually look for the spark first. If you have a spark then your issue is the feed to your burners or the burners themselves being clogged. The feed is like a straw should there be an obstruction than nothing passes through. Clean the burners with a pin, blow through the gas inlets that go to the burners. After cleaning retry.
Oct 13, 2009 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Jul 15, 2009 | Maytag MGC5430BDS Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Gas Range Continuous Spark
On all gas stoves/cooktops, when you switch on one burner to light, all other burner igniters will click at the same time. This is normal. Enjoy your new apartment!
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Cooktops
Dacor Preference SGM466 Gas Cooktop Logo
552 people viewed this question
Top Dacor Cooktops Experts
Marvin
Marvin
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
