Question about Ricoh Office Equipment & Supplies
Ricoh Fax 5000L 3-31 Error Message
I am working on a Ricoh 5000L Fax with a 3-31 error message. Any assistance would be appreciated.
jaylex
  • 417 Answers
SOURCE: Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
Posted on Jan 06, 2008
jaylex
  • 417 Answers
SOURCE: Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
SOURCE: Error message Sharp FO-4450 Fax machine
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Posted on Jan 16, 2008
jaylex
  • 417 Answers
SOURCE: Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Posted on Aug 17, 2008
tech435
  • 284 Answers
SOURCE: Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
you can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Posted on Sep 17, 2008
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
Can send Fax but not receive error message 0-22 on the fax report
The error message means you have received an fax but there were problems because of poor line condiotions. Ask to resend. Here is lonk to manual.
Ricoh FAX5600L Operator Manual Error Codes
Jan 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Hello, I have a fax machine which is for business use and used daily throughtout the day, we have a problem, the fax machine is a RICOH Fax 1140L. There is an error on the screen sayinh 'Printer Error...
There is not much that can be done from the outside as your fax is showing an error due to a failure in the system circuit. Best that can be tried is to remove paper, clean the head with a soft cloth clean the paper insert section. Put the fax on and if the fault message comes on again, you will need to open out the set to probe into the main board. remove back panel and reinsert all connectors , If there is no result, you will require help so that we do not tamper much. Good day
Aug 14, 2010 | Computers & Internet
Our fax has the following error message: Printer
Press
Function
7
monitor key slowly 4 times
6
scroll sdown to SHIPMENT SET
set
wait for the machine to initialize
Nov 24, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Thanks J
Nov 27, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Apr 17, 2007 | Ricoh FAX5000L Plain Paper Laser
Canon D680 (Fax and Photocopier)
1. Press ?additional functions? key. 2. Press ?#? key. 3. Press the ?>? key until you get to number 7. 4. Press ?Set?. 5. Press ?>? key until you get to number 4 (printer reset). 6. Press ?Set?. 7. Select ?yes? if in a fuser error. If this does not work, you will probably need a new fuser unit. Ed
Jan 21, 2007 | Canon imageCLASS D680 Laser Printer
137 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
