Question about PC Chips M955G Motherboard
Installed motherboard into a new case, but now not sure which wires goes where? such as the power switch, speaker, reset, power led. any help would be great. Thanks in advance, Dave
  • dagid Dec 22, 2008
    If I'm not mistaken the board is a M955g or at least that's what I found on the board. The board came out of a "e machine t1840".
    I hope one of those numbers help you out.
  • Roberta Smith
    Roberta Smith May 11, 2010
    if you have the manual for that motherboard... the connections are shown there... if not let us know the exact board you have and we should be able to locate the manual
  • 837 Answers
Posted on Dec 21, 2008
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
I am going to be fitting a new motherboard, and I am worried about fitting in the power and the wires? Any advice??
There are only a few things that must be carefully observed when changing out motherboards. The first is to ensure that the mounting lugs match up with the mounting holes on the new board. Remove any that don't, otherwise they may short out the motherboard. The new motherboard will come with a book that will show the external connections that must be made from the case to the motherboard. Most cases have labeled plugs that will correspond to the information in the manual. There are two plugs that can be confused - Power Switch and Power LED. Power switch is used to turn on the machine, Power LED goes to the green light on the front of the case. Alos, the HDD LED and Power LED connections are polarized, meaning they have a + and a - wire. The Power LED wires on most cases will be green and white with the green wire being the +. The HDD wires on most cases will be Red and White with the Red being the +. If you get them reversed, it will not harm the machine, but the LED will not work and you will have to turn the plug around. The plugs for the power switch, reset switch and speaker (optional) are not position dependent and cannot be installed backwards. The large power connector to the motherboard is keyed and cannot be installed backward. They can, however be very difficult to connect fully and may required forceful pressure to seat. If this is the case, place something firm, but non-conductive under the edge of the motherboard below the socket to prevent cracking the motherboard. Also, while this may seem silly, some people accidentally do it, so I'll say it here, do NOT have the power supply plugged in when making any connections to the motherboard or when installing or removing any expansion cards.
Jan 13, 2012 | ASUS P5GC-MX/1333 Motherboard
I have installed a new motherboard in an acer case. The power cable from the switch on the front of the case will not connect to the board. Can anyone help? Thank you
You should read the motherboard manual, for cabling:
1. Power SW
2. Reset SW
3. HDD led
4. Power led - and power led +
5. Speaker
Cabling scheme, also written on the motherboard.
If the Power SW not installed the switch on does not work.
If the Reset SW not installed the switch reset does not work
If the HDD led
not installed the hard drive light (red) is not lit
If the Power led (+/-) not installed the power light (yellow) is not lit
If the Speakers are not installed, when the computer is on the beep sound is not heard.
I hope this information helps.
Oct 15, 2011 | Computers & Internet
Installed Crosshair MB in new case. Motherboard LED lights come on but CPU and fan do not light up or turn on. Tried dif power supplies and cases, no luck.
Make sure that the motherboard LED switch on the back panel is set to off and if want to turn it on go into bios and set it. If it is active thru switch and not thru motherboard bios it will not allow you to turn on PC cause it is in maintenance mode.
Oct 26, 2009 | ASUS CROSSHAIR Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Labeled Technical drawing of where the power switch, reset switch, power led, HDD led etc. connectors go on my comp
Most motherboards have near where the pins the wires go what goes where and the wires from case switches have writing on them as well give it a try
Jul 30, 2008 | Computers & Internet
Dead new motherboard
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Wiring
see the picture below:-
Sep 07, 2007 | MSI 694T PRO (6309-470) Motherboard
PC Chips M955G Motherboard Logo
121 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
