Question about HP Computers & Internet
Error with file C:\program files\HP\Digitalimaging\{20B30DC1-E423-4939-B51D-05C58B0F9BBB}\hpzsetup."-"error""-wstub.""66398"
  • 26 Answers
This looks like a problem with and HP printer. Uninstall the printer and reinstall it.
Possibly use a driver only download from the web (all in one drivers sometimes cause problems and have conflicts with other programs.
Posted on Dec 22, 2008
When trying to play a video in full screen computer shows R6025 error and stop playing it
  • Close down the program entirely that threw the R6205 runtime error message. Press "Ctrl-Alt-Delete" and select "Start Task Manager."
  • Click the "Processes" tab and click on the "Image Name" column header. Scroll down through the list of programs and check to make sure the original program that gave the error message is not on the list. Click on the name of the program if it is in the list and choose "End Process."
  • Close the task manager window and click the Windows "Start" button. Select "Control Panel" and choose "Uninstall a Program" under the Programs section. Select from the list of currently installed programs the program that caused the error and click "Uninstall.
  • Click on the Windows "Start" button, type "cleanmgr" into the Search field and press "Enter." Click on "Files from all users" if it asks and select "Continue." Choose the drive where the program was installed, check the boxes next to "Temporary Internet Files," "Temporary Files," "Recycle Bin," "Downloaded Program Files" and "Setup Log Files." Click "OK" and select "Delete Files."
  • Wait for the program to finish cleaning the files on your hard drive. Re-start the computer. Insert the installation CD for the program you deleted earlier or go to the website of the manufacturer and download the program again. Install the program.
  • Open the software program by double-clicking on its desktop icon or clicking on the name of the program in the "Start" menu under All Programs. Attempt to use the program to make sure the run time error message does not appear again.
Jan 01, 2014 | Sony VAIO Computers & Internet
DHP 301
Many errors surface soon after you install new hardware or software because conflicts often occur between the new product and previously installed components. To put an end to such messages, you might be able to uninstall the program or hardware (and hardware drivers) and then restart your computer to an errorless state.
If you do find that removing a new product eliminates errors, you might have to do some research to figure out the source of the conflict before you can reinstall the new product. Check the manufacturer's Web site for updated drivers, search support areas for known conflicts, and contact technical support for assistance. Sometimes tech support gurus can help you tweak a setting to end software conflicts.
Let it finish. Developing new computing habits can also limit the number of error messages you see. When you first start up your PC, let the hard drive come to a complete stop before starting a task; this lets your computer load all necessary drivers and operating system components necessary for efficient and error-free operation. The same concept works for your other programs. Let each program start up or shut down completely before you move on to another job.
Feb 16, 2008 | D-Link DHP-301 Transceiver
I'm getting an error message of 0xb900009f
Lots of issues can be responsible for your error message:-
Access deniedThis error occurs if the user has insufficient privileges to a file, or if it has been locked by some program or user.The device is not readyThis error most often occurs when there is no floppy disk (or a bad disk) in the disk drive and the system tries to perform tasks involving this disk.File not foundThe file concerned may have been damaged, moved, deleted, or a bug may have caused the error. Alternatively, the file simply might not exist, or the user has mistyped its name.Low Disk SpaceThis error occurs when the hard drive is (nearly) full. To fix this, the user should close some programs (to free swap file usage) and delete some files (normally temporary files, or other files after they have been backed up), or get a bigger hard drive.Out of memoryThis error occurs when the system has run out of memory or tries to load a file too large to store in RAM. The fix is to close some programs, or install more memory.[program name] has encountered a problem and needs to close.
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
While adobe photoshop 7.0 installation, error115 coming.please tell me solustion
Your error message will have a file name with it, below is an example of the error.
Media Name:Data
Component:TypeSpt\CommonCMap
File Group:Reqrd Common CMap
File:C:\Program Files\Adobe\Fonts\Reqrd\Base\pfm\COBO__.PFM
The file COBO_.PFM is the file causing the issue in this case. Check the file name in your error message. Goto the location mentioned in your error and cut and paste the file on your documents folder.
E.g. "C:\Program Files\Adobe\Fonts\Reqrd\Base\pfm\" as in this error.
Try reinstalling the Photoshop.
Regards,
Shrey
May 30, 2011 | Adobe Photoshop 7.0 for PC
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
C;\Documents and Settings\admin\My Documents\downloads\Silverlight.exe is not a valid win32 appplication
HI,
causes for these problems are:
1. File is corrupt, bad, or missing.
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file.
4. Hardware incompatibility.
Step 1: Verify that the program installation CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
Step 2: Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors.
Step 3: If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
· If the program is an older MS-DOS program or early Windows program you may get this error.
· If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Step 4: Run an online scan for any threat and try to fix them
http://onecare.live.com/site/en-Us/center/cleanup.htm
Thanks and regards
Nandy
Oct 26, 2010 | Microsoft Computers & Internet
Error 1305.error reasing from file c:\program
If it is a valid error, not a virus or whatever,
these programs have security ideosyncrasies
which demands all files stay in place and unchanged
or they will protest to the point of not working.
You cant just delete from a program what you dont like
being there anymore.
These error reports are horrible.
They are not user friendly.
With every error should be a valid solution.
Even if you need a gig of database for the error reports.
The solution is to force the gaming industry and
software developers to include layman type solutions to
all thir errors possible.
Jun 20, 2010 | Microsoft Flight Simulator X
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Error Message 'F:\ setup.exe is not a valid win32 application'
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
Computers & Internet Logo
258 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
