Question about Dryers
Our proline tdv62 is blowing cold is this the heater element that needs replacing or could it be the thermostat please help
  • 3,463 Answers
It could be either the element and or the thermostat(s).
The only way to find which one it is , is to meter the element and stats for continuity..
If you have a meter, set it to the ohms range, and check reading, you should get full scale deflection if they are o.k.
If no reading, then it is faulty.
Hope this helps you.
Plz rate my solution.
Thanks.
Posted on Dec 23, 2008
Heater not working ?
There could be more than 1 thing wrong, I assume the fan works because the A/C blows cold, as for the heater is it blowing luke warm or nothing at all. If the thermostat was removed and left out you would have luke warm air because the water that circulates through the heater is not getting hot if this is the case replace the thermostat with the correct one, another issue would be the heating element under your dash has no power to it or the element has deterioated.
Dec 19, 2015 | 2005 Chrysler PT Cruiser
Mobile home electric furnace multiple problems
Hello im not familiar with this model, but looking at the schematic for the models its similar to a heater blower. as you say it is heating up but only blowing cool are but the thermostat is turning off as its getting hot, the only thing i can find that would make it do this is if its blocked on the heater element, or the heater element is only half working, the device has a thermal fuse on the heating element this could also be a problem you would need to remove the try that hold the heater element ands test the heater element with a meter to see if its working if that's fine, then one of the thermal switches would be at fault. there is alot of model number for this brand but they all have the same setup. the panel for the heat looks like it only has 2 screws hold it in place, but disconnect the fuse before opening the unit. there is 2 setting on the heater elements that means there is 2 elements one top and one bottom in the case. there is also 2 thermostats on this model im looking at that are for the heater controls these would when they get to the temp required turn the elements on and off. there is also a thermal fuse that if the element gets to hot with turn it off. check these. remember dont open the unit until the power is off and disconnected from the mains supply . personally i would think the thermostat switches need replacing, these are cheap to replace the part number is on them use the same part number to get the right part ebay or heating suppliers will have these parts in stock, they wear out as they the only moving parts apart from the fan but thats working or you would not have cool air.
Jul 04, 2017 | Coleman Heating & Cooling
Car heater blows cold air
It could be the heater control valve make sure the vacuum line is connected to the valve and that it is working properly. If it is not replace the valve. Hope this helps.
Jan 09, 2014 | 1999 Chevrolet Blazer
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a 2001 dodge stratus and the heater only blowed cold aire now we changed the thermostat and it blows warm air when idling but when driving still blows cold need some help please
where did you buy your thermostat? if you bought a fail-safe style thermostat it could have been no good before you even put it in. also is your tempeture gauge coming up to operating temp?? if it isnt your thermostat may be stuck in the open position allowing the coolant to circulate freely and not actually warm up. i would also check the lines going into the heater core. if one line is hot and the other line is cold than your heater core is probably in need of a flush or replacement.
Dec 01, 2010 | 2001 Dodge Stratus
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Heater blowing hot then suddenly blows cold and engine overheats. Intermittent problem. After engine cooled may overheat again with heaters blowing cold then suddenly heater blows hot again and...
I have written a tip on this.
You may have a couple of problems. I would first replace the thermostat, and make sure you have the proper coolant(ant-freeze) level.
Please let me know how it goes and if you need further help I am here.
Feb 09, 2010 | 2002 Toyota Celica
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
Blows cold air only
replace thermostat
Apr 15, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
