Question about RaidMax Aurora RX580 (RX580F) 580-Watt Power Supply
Newly installed, first boot up PSU problem
I made sure to install everything correctly, but the first time i turned on the computer with the new PSU, it started, lit up for about a second, and then shut off. After I unhooked it i heard a strange whirr or woosh noise come from the PSU. Is it a faulty unit?
  • 1 more comment
  • Brent Wever Apr 06, 2007
    BTW, I tryed my old PSU in my system again and it works, so im pretty sure its not my motherboard.
    pretty sure this PSU is compatable with AMD, i'm going to send it back today, and go buy another.
  • Anonymous Mar 28, 2014
    my dell desktop wasn't turning on so changed the voltage of it the red thing at top from 230 to 215 when pluged a bang with noise and smoke can you tell me will my memory be lost because my document homework
    Scholar:
  • 121 Answers
If it's a new PSU, then return it for a replacement...Even online distributors will replace faulty units. And since your old PSU works on it, I'd have to say it's the new PSU that's faulty. Did you make sure that it's the right PSU for the CPU that you have? (As there are PSU units for AMD and seperate ones for Intel...Intel just has a additional power cord to connect to the motherboard)
Posted on Apr 06, 2007
Dram Led on my motherboard blinks red twice
Don't panic. take a good light above your computer and start checking if every card and every connector is still correct inserted. Feel if nothing is lose. Even cards you did fasten with a screw, remove the screw and look and feel if the card was inserted correct. Everything you inserted in the motherboard should be checked. It could be a card you did not put in correct at the first time, but still made contact and only got lose because of some tension to shock.
Jul 03, 2014 | ASUS - MOTHERBOARDS Asus M5a97 R2.0...
Msi 870-g45 failing to POST?
hi, i had a similar issue some time ago, dependng on your hardware i would suggest you look into a psu tester, or swap it out for a friend's psu, i assume you've ripped everything apart and put it back together to see if some dust was shorting somewhere, is it related to heat maybe, expansion of cracking can sometimes occur in computers that have gotten hot in the past, especially in the circuitry behind the cpu.
Good luck
Nik
Jun 04, 2012 | MSI 870G45 AM3 AMD 770 ATX AMD Motherboard
Pc wont boot, MCP73PVT board, i have checked the ram, processor, heat sink and psu,cmos batt and still no joy, its starts for 4 seconds and turns off, all fans come on but nothing else no beeps
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | Packard Bell (181368) Motherboard
How do erase everything off my computer so ill be starting fresh and like new
Install newly through follow the step>gon bios >set boot piorotity>cd rom first>restart with xp bootable cd >enter >delete partition.create partion>install.
OR
go start >progame >accesaries>system tools>restore>choce previous mknth>previous date which is better .
Nov 21, 2010 | Computers & Internet
I have a dell gx 260. orked great for 1 month when
Hello there:
It looks like to me that your bios is not recognizing the harddrive or is not set up properly like user settings or default settings
I would first go into bios and make sure that the bios is set to the harddrive that is installed.
And also in the boot sequense look on this and see if the harddrive is listed there if it is make sure that it is the top one and not the bottom one than save and reboot the computer when it boots back up it should tell show your harddrive and cd rom if connected properly than if all is good now just continue with your xp[ installation or what ever you were doing ok
I hope that this is very helpful for you
best regards righard
Nov 16, 2009 | Computers & Internet
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
My computer keeps restarting after I installed new hardware
Make sure that all of the new ram sticks are completely pushed down. Also confirm that you used the correct Ram for you Motherboard.
I would also make sure that all power connectors from the PSU are tight.
I would also reseat the video card. As well as making sure you have the correct drivers instaled.
Sep 16, 2009 | HP Pavilion a6600f Desktop PC
I replaced my power supply with a new Antec 650
Let give it a try.
Turn off your computer and unplug it from main supply. Remove the battery for cmos bios. wait half an hour. insert battery again and reset the cmos through jumpers. Plug the main supply and start your computer.
May be it can help you.
Sep 07, 2009 | Antec 650W EarthWatts ATX Power Supply 80...
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
PC wont Boot/start
try another graphics card if you have a working spare
Feb 16, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
RaidMax Aurora RX580 (RX580F) 580-Watt Power Supply Logo
131 people viewed this question
Top RaidMax Computers & Internet Experts
Alun Cox
k24674
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
