Question about Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
  • kzinger Mar 31, 2009
    The directions that came with the watch look nothing like the links on my watch.
  • 2,338 Answers
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck
Posted on Dec 21, 2008
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Aug 14, 2010 | Citizen Watches
How do you remove the end link?
take it to a repairer is my advice. but if you want to try you need a very lite hammer a very fine nail and a block to place the bracelet on its side. see what i mean..you do need the correct tools for this job as you may scratch the watch or damage the pins and barrels in the bracelet..place the watch on the side place and you should see the pin thats holding the bracelet section hit the pin on top with the very fine nail and it should push the pin through the bracelet you have to do this twice also there will be either 1 or 2 barrels inside the bracelet when you knock through dont loose these ..but you will be in tears by now as you have prob damaged your bracelet repair could be 200.oo .....instead of 20.oo to remove links....
Mar 26, 2010 | Omega Seamaster Planet Ocean Chronograph...
How do you remove a link without using any tools
You don't say much in your question ...
So ... I'm guessing ...
I'm guessing you have a watch with a expansion band that has removable links.
I'm also guessing it has a snap fastener and you have already made your band smaller through adjusting that part of the bracelet.
I'm guessing that yours is of a similar design to several I have owned and/or adjusted for others.
I'm guessing you have a paper clip in your home or office and ...
I am also guessing you never thought of a paper clip as a tool.
Straighten one leg of the paper clikp and pop out the little keeper on two of those links, reattach the loose ends for a smaller bracelet. There should be a little arrow pointing in the direction you should push the little clip/keeper.
I hope this helps you make your bracelet the size you need it to be.
Thanks for your question at FixYa.com
Jan 08, 2010 | Watches
Adjust-a-Casio-S-1087DY-Watch-Band
On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
which should help you to remove the link pins safely without scratching.
Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
How to remove a link from the bracelet
That job would best be left to a Watchmaker/ jeweler.
Sep 23, 2007 | Cartier Santos W20056D6 Wrist Watch
Link removal
here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at Info@Webjeweller.com 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: Info@WebJeweller.com Copyright © 1999-2006 webjeweller.com. All rights reserved.
Aug 10, 2007 | Fossil AM3425 Wrist Watch
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Timex 2J611 Watch Logo
1,016 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
