Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
KUDD01DPPA Flood Switch
The flood switch is triggered and the dishwasher attempts to drain both drawers. Neither has water in it, so the sensor is malfunctioning or something is triggering it.  I was able to run both drawers successfully last night, but this AM I awoke to the machine trying to drain itself and signaling it's alarm (with 2 red lights flashing and beeping).  I installed this unit 4 years ago, so I can effect a repair if someone smarter than me can provide direction Thanks, m2
  • morganvpi Dec 22, 2008
    I followed Classyexperts advice, but no joy. Other suggestions?
  • 750 Answers
Welcome.
If this continues non stop shut the breaker. Sounds like a relay is jammed. You do not want to burn out the drain pumps running dry!!!!!!!!!!!!
Call service.
You do not want to damage such a fine piece of machinery.
Thank you for trusting us with your questions.
please remember to leave a solved rating before you sign off! Sincerely, Huum
Posted on Dec 22, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try:
  • unplug from the mains;
  • use a can of compressed air or a compressor to force dry the drain area with particular attention to the sump or where the flood switch is located;
  • you could also use a hair dryer set to a reasonable heat level with strongest air flow to do the same;
  • not technically sound, but you could also try laying the machine on its side for a couple of hours.
The above are based on the possibility that there are no defective parts but rather condensation, moisture, water droplets is false triggering any of the sensors. Should this be not corrective, a temporary workaround is removing and covering at least one of the wires/connector leading to the flood sensor.
An exploded parts diagram may assist you identify parts location.
Good luck and Thank you for using FixYa. Happy Holidays.
    Genius:
  • 2,920 Answers
I think your control panel is going bad...thats what it sounds like anyway...you might check it out and see
Posted on Dec 21, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Before doing any thing just unplug the dishwasher from mains for two minutes then clean the diswasher completely if any thing in it.and then reconnect it and check out.
Fisher & Paykel DD24DCTB6 top drawer beeps instead of starting
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
Mar 18, 2013 | Fisher and Paykel Dishwashers
My dish draw **** up with a service code f 1 , what does this mean
This can mean several things. If you have double drawer dishwasher then you need to confirm if you get the F1 message in both drawers or just one.
If both drawers then it is caused by water leakage and flood switch activiates. If only in one drawer then the power supply to the other drawer is blown.
For single unit drawer it means flood switch triggered.
Dec 26, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
How do I turn off the flood switch sensor on a fisher and Patel double drawer dishwasher
Unfortunately there is no way to turn the flood sensor switch off, you need to pull the lower drawer all the way out and check for any water in the base or other items affecting the flood switch, If you have a 601 series you need to pull the 2 round pins out on the front sides of the drawer to enable you to pull the drawer out enough to get to the flood switch, If you have a 603 series you need to push in the 2 locking tabs on the front side of the drawer which will allow you to pull the drawer out enough to check the switch. Make sure you unplug the dishwasher before doing this,
Mar 04, 2012 | Fisher and Paykel Dishwashers
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers on our dishwasher will start by it self and will display "F1". In our user guide - it tells us "flood switch has been activated". How can I fix it?
Hi
Error F1 on your fisher & paykel means an overfill condition. One of the most common causes for an overfill fault is that the dishwasher cannot pump out the dirty water due to a plugged drain hose. Check the drain hose if it is clogged. Now remove the bottom drawer from the unit to inspect the flood switch. Remove the wire harness cover on the underside of the drawer. With the bottom cover off, unclip the wire harness, fill hose, and drain hose. Then unclip the linkage at the back of the drawer and lift the drawer off the slider arms. Now' you'll be able to look at the flood switch. Note the positions of the wires on the flood switch and remove them. Then unclip the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. Now clean the contacts and let it dry. Hope this helps... Please post back if you need more information.
Jan 31, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel Dish Drawer flood alert switch
Switch the main power off and on after a short time. If the error does not go away then you have water collection in the base of the dishwasher under the drawer.
Take the bottom drawer out and try to use a couple of towels to dry out the base plus use a hair dryer. (make sure the power is turned off at the mains switch). This should dry out the flood switch.
Now about the reason for water collection - could be kink in drain hose, water leak from drawer seal, foaming due to incorrect detergent.
You have not mentioned if the error is occuring in both drawers or just one.
Jul 13, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Code F1 keeps draining constantly
Turn off the main power to the dishwasher.
I am assuming you are getting F1 error code flashing on the LCD display. This occurs if the flood switch is activated.
The flood switch is located at the base of the drawer tub. You will have to either extend the drawers out fully or take them out depending on the amount of water that would have collected at the base of the tubs. Get some towels and dry the base out. You may also need a hair dryer.
Once the flood switch dries off the drawer should work ok when you turn back the power.
The causes of the flood switch trriggering is either too much foam in detergent (use recommended detergent) or leak in water in or drain pipe.
Please remember to rate the solution if it helps or post a comment if not.
Jun 12, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
The flood switch has been activated on our Fisher & Paykel 2-drawer dishwasher. How do we reset the button?
I am assuming you are getting F1 error code flashing (if your drawers have LCD display) or the LEDs are flashing if you have intergrated drawers.
Jun 12, 2010 | Fisher and Paykel Dishwashers
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
120 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
