Question about Epson Stylus R265 InkJet Photo Printer
Epson R265 printing colours incorrectly
Printer has been working fine then started to print in completely the wrong colours. It started when I was trying to print some black and white photographs and it printed in an orangey colour instead. I have tried to print a colour photograph and the skin tone is coming out very magenta. I have checked and cleaned the print heads and on the check the dark cyan was not printing at all. Any help or suggestions greatly appreciated. Thanks!
    Sergeant:
  • 195 Answers
For the black and white issue, check the settings and make sure that it isn't set on "sepia". As for the color issue, it is quite possible that you are out of ink. Printers may use more of one color than another depending on what you're printing. Change your color cartridge.
Posted on Jul 02, 2017
SOURCE: Print is right when preview is very magenta (like 40 pts magenta)
This sounds like a calibration problem. The first thing I would try is to un-install the driver, download the latest drivers from the manufacturer's website then reinstall the new software.
I'm not familiar with the drivers of this printer but look to see if there is a printer/monitor calibration area try the settings there.
The other obvious place to look in is the software you are printing from. Try printer/Monitor calibration in the help menu
Posted on Jan 24, 2008
SOURCE: Epson Stylus R230 Light Magenta Not working
I would recommend cleaning the contacts (brass colored connections) with an eraser if might resolve the issue. It that does not resolve the issue it might be one of two other things. Either the printhead is cloged or the cable to the printerhead is damaged.
Good luck
Posted on Mar 07, 2008
SOURCE: Epson 1290 printer
Fix posted yesterday BUT after a few perfect print outs the problem seems to be recurring.... will report back later. Trant
Posted on Mar 29, 2008
BinaryCode
  • 54 Answers
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Posted on Jun 12, 2008
diddydaveh
  • 154 Answers
SOURCE: how to scann photographic film fith epson scanner
Hi, I'm sorry to saythat this unit (DX4400) doesnt have the facility for film/negative scans
Posted on Dec 16, 2008
Epson R265 - prints blank (new inks & paper loaded)
Check the cartridges installations and make sure they're well installed.
Make sure the plastic tab around the new cartridges is completely removed.
Disconnect the printer completely and re-connect after a while.
Turn it off and on.
Problem solved?
Uninstall and install the printer again.
Hope this helps.Thanks!
Nov 10, 2011 | Office Equipment & Supplies
EPSON R265 cd/dvd printer can not print in black colour I have tried to reintall the driver but still can't print in black ink. Other colours print well. Ink cartridges are new.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 06, 2011 | Epson Stylus R265 InkJet Photo Printer
I have an Epsos Stylus Photo R265 printer. I want to print a Word doc in b&w not colour. How do I turn the colour setting off for the printer? ipmcg73@yahoo.co.uk
After pressing print, when you're on the print page, click "Printer Settings." You should have some color settings, one of them being black and white.
Mar 02, 2011 | Epson Stylus R265 InkJet Photo Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
My Epson R265 prints all of the colours green
Sounds like colour contamination to me.
Check the carts are in the right slots.
then print until it clears the problem.
May 09, 2009 | Epson Stylus R265 InkJet Photo Printer
Re R265
To print CD/DVD use the prg Epson Print CD for the Epson R200. It works fine and all troubles will result solved. The prg coming with R265 fails and crashs. Nothing to do.
It's a shame for Epson.
Solved by Fiorello-Italy
Aug 23, 2008 | Epson Stylus R265 InkJet Photo Printer
Re: DVD labels won't print on my Epson R265
Hello guys.
About the problems printing CD/DVD with your Epson R265 ....................
There is nothing to do. The prg coming with the printer (PrintCD) is wrong at all and we cannot understand why the Epson Corp. has simply deleted the prg by its download site.
After tryng for a lot of solutions ........ INCREDIBLE but TRUE ..... the program Print CD coming with the previous Epson R200 is ok at 100% !
So, in conclusion, all prgs inserted onto the Epson R265 CD are OK eccept the Print CD. Don't install it from the R265 disk ! It will crash !
If already installed, delete it and install the prg Epson R200 print CD.
It will work fine and without troubles.
Repeat ... it's incredible, but true.
The prg can be downloaded searching for Epson R200 software.
If you will have troubles, let me know.
R265 WILL NOT PRINT TO CD
Use the prg Print CD coming with R200. It works fine.
Jun 08, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
Check status monitor if empty or low:
Replace if empty ect:
Soak the cartridge nozzles upright in Flush Solution for 6 hours dry and retry , make up a A4 Paper colour printing page with each colour band about 1" high x 8" wide and print out 4 - 6 pages checking which colour band is poor:
Keep printing if improvement noticed:
if not
Resoak the offending cartridges and repeat:
also can
Use cleaning cartridge on offending colour slot/s then retry:
Dont use the head cleaning utility to much as it is programmed to disable your printer after a pre-set number of cleans and will have to be serviced:
cx3200@tiscali.co.uk
Dec 21, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
