Welcome to FixYa
Dear Sir/Madom,
You can Update your Firmware Easily.For getting firmware Update you need to Know and to Enter "Magellan Serial Number" in Specified area[Right top] -Then Click Submit Button..
How to Update Guide[Complete instruction] Here and Save it.
An SD card is required if your GPS has a Firmware version lower than 2.36 To check if you need an SD card, follow the steps below:
Select "user options"
Under user options select "system settings"
Select "next"
Select "Product information". Under product information you will see “Firmware version". If it is less than 2.36, then you need an SD card
To get Manuals and More Click here[Select your Exact Model,My Magellan is-Bottom Right page]..
I hope Now you got an Idea and Ready to Make Update....
Thanks for Using FixYa....
The only free update for your 4040 is the latest firmware or you can call the tech support of Magellan and ask if you can still avail the latest maps for your 4040 don't forget the recepit when you call them, they may ask you to send it to them for verification.
make sure its not muted or volume turned down. if ok then use the hard reset on the side (tiny hole)use paper clip to reset it. if none of those work check your firmware version and see if its the latest..i have the latest updates for magellan 2200t 3100 3140 4000 4040 and 4050
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps
Updates
Magellan Maestro 4040 Voice Upgrade
Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
To purchase an Authorization Code you will need to:
Login to your existing user account, or create a new Magellan user account.
Register your product if you have not already done so.
Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and chk on the magellan website to see for firmware update if it is do it and plug in powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .also make sure it has a flash sd card in it so you do not lose your addresses.let me know what happens.
I had the same problem, you need to format the SD card. BUT before you even do that, go under your settings and you'll see your current firmware version. I went through 30 minutes of messing around to find out I had 2.36 already!
The same thing happened to me.
