Question about Nikon Coolpix 4600 Digital Camera
Memory card?? I posted before about when I turn my camera on it says the card is write protected but the lock switch isn't on. I tried cleaning it as suggested but that still doesn't work. Is there some kind of setting in the camera that would fix it?
  • 944 Answers
The way to check that for sure is to try your card in another camera or a card reader on a computer. If you can write to it fine there, then the problem is likely to be in the socket where the card goes into the camera - check there are no bent pins or dirt or corrosion. Also if you can borrow another card, try that in your camera and see if you get the same problem. If the card still says it is protected in another machine, and another card works fine in your camera, then the fault is with the card. Unfortunately these are rarely fixable, but if you take the card to an electronics shop, or fancy trying yourself, then if it is opened up the problem might be a mechanical problem with the write protect switch and it may be repairable, but it would be a fairly complicated job and certainly no guarantee of success. Hope this helps :)
Posted on Apr 06, 2007
    Problem Solver:
  • 46 Answers
May be you should see the settings of your memory card, may be its lock! try to configure in it!
SOURCE:
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
My fujifilm finepix jx 300 says protect card even after sliding the switch on memory card to unlock
check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
Nov 15, 2013 | Fuji FinePix A303 Digital Camera
Says memory card protected when I try to use it
If card lock button isn't faulty and doesn't free by sliding it a few times does your camera have a memory lock function in the menu?
Sep 27, 2012 | Panasonic Lumix DMC-FZ7 Digital Camera
Memory card write protected messgae when i turn on camera (lock is not on)
It sounds like the sensor make be blocked. 1. check with another card and verify the tab isn't damaged. 2. use canned air to blow out lint or dust from the optical sensor that sees the tab.
if it's a switch rather than a sensor, it may be damaged or have a rusty contact. a shop can clean or replace it.
Mar 18, 2012 | Nikon COOLPIX P5000 Digital Camera
Wat is write protect
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card, allowing the camera (or any other device) to write to the card.
Mar 18, 2011 | GE Cameras
I slip in memory card and turn on camera and get a printout card locked. what do I do
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 12, 2011 | Canon PowerShot A520 Digital Camera
When camera is turned on it says memory card is
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Jul 21, 2010 | Kodak Easyshare C813 Digital Camera
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
