Question about JVC KD-DV5000 Car DVD Player
Suddenly stop working
I have jvc cd player . it stop working whan i rase vol with beat and after some time it start working again every time againand again.
could u tel what it have how can i solve this problem.
looking forword to hear u
thanx in advance
ahmed
    New Friend:
  • 20 Answers
Ok this might be caused either by drop of voltage available to the player or by physical vibration of the disc disabling the laser lens to focus on the surface of the disc and read the data. You may diagnose this yourself. Play the same music rising the volume level, until it stops playing. Note the level. Turn on lights, blower and heated seats if you have them and do the same test. If on the second try, the music stops playing earlier-on lower volume level than the first time, you have a problem with your wiring or your alternator, because the car does not have enough power for the unit to keep playing as it is sending too much power to other appliances. If on the second try it stops at approx the same volume as it did on your first try, it means, that your car stereo vibrates too much for the lens to focus on the disc. You may try fixing your speaker setup tighter in the car chassis/door frames. You may also take the JVC unit out of the dash and mount it somewhere further from the speaker-induced vibration.
Posted on Jan 13, 2018
5 Suggested Answers
SOURCE: i c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Posted on Dec 07, 2007
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Posted on Feb 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: no audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
  • 152 Answers
SOURCE: MY JVC CD CAR RADIO DETACHABLE FACE LIGHTS UP LIKE
If this unit worked in the past, and there have been no repairs done that would have disturbed the connections, then its quite possible that you accidentally engaged the mute feature.
Good luck...
Posted on Feb 24, 2009
I have a yamaha cdr-hdd 1500 the problem is to record from hdd to cd it makes an image file ok but it stops whan it starts burn the cd after 2 min
Try burning at a normal speed [longer process], if successful, erase the burned tracks from your harddrive.
or rearrange your tracks, starting with older recording dates, then
burn at high speed.
Jun 09, 2010 | Yamaha CDRHD1500 CD Player
Set time on jvc kd g420
CLICK HERE for the owner's manual.
Setting the time is covered on page 12.
Press SEL button
Scroll through the PSM menu items with |<< and >>| until you come to CLOCK H
Adjust by turning the VOL knob
press |<< or >>| again until you get CLOCK M
Set again with the VOL knob - then press SEL again to exit.
Thanks for using FixYa!! A 4 THUMBS rating is appreciated for answering your FREE question.
Jun 02, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-SX780 All of the sudden--just stopped working.. If you touch the "display" button--the display does come on briefly--otherwise nothing.. Any ideas??
There is a grounding tab on the back of the unit just above the antenna connection. This must be solidly connected to a GOOD ground. Found out the hard way myself. Once ground was established, I never had that problem again.
Jun 03, 2009 | JVC KD-SX780 CD Player
Does not play any disc
Thats bad..Did you try another disc? If this happens even with a different disc. You will need to get a lens cleaner(costs about 5$) and try cleaning the lens. If it still doesn't work then you will have to replace the lens. The reason why it died suddenly is probably because the lens circuitry somehow got shorted. Try cleaning and if not.. replace.
Nov 14, 2008 | JVC XV-N212S DVD Player
Cd player broken
unplug the radio from its harness for about a minute then plug it back in try the radio again if you still get that squeal-it is possible that either one of your speakers is shorted or your wiring has a problem- cleaning will not help this problem!
Mar 26, 2008 | JVC KD-S570 CD Player
JVC KD-SH99 Skipping
try cleaning the lazer lens, also remember it is old and is most likly toast., the longest I ever owned a deck that didnt go out was 4 years.
Nov 12, 2007 | JVC KD-SH99 CD Player
Jvc 48" tv model av-48wp34
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
Jun 18, 2007 | JVC AV-48WP30 48" Rear Projection...
CD Player
I'm currently having the same problem. Take the face plate off. Use a pin to reset the stereo. It'll probably stop working again, but at least you'll be able to get your cd out and take it somewhere to have the stereo fixed or replace. (STAY AWAY FROM JVC!)
May 20, 2007 | JVC KD-G200 CD Player
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
JVC KD-DV5000 Car DVD Player Logo
32 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
