Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca 52 inch tv model r52wh74yx66/power on problem/three lines
I had a problem with the convergence and replaced the fuse and it fixed the problem. it happened again 6 months later i replaced the fuse and it worked for a while then it went out but the fuse wasnt blow this time becasue the option was still there it just wouldnt adjust. Now for some reason it will work but when it goes out you have to unplug the tv for a while for it to work or beat the side and front of the tv(im serious) something loose mabye?
OK, so the last time i used the tv it was working fine then all of a sudden it showed 3 small horzontal lines green, red and blue then it powered off. When you try to power it on it turns on for a few seconds then turns off by it self. it will turn off and on by it self a few times and every time it turns on it shows the 3 lines then nothing.
any help would be awsome
  • 4 Answers
Quite costly those new bulbs!
Posted on Dec 21, 2008
  • RCA Master
  • 5,138 Answers
Check capacitor cp150 2200uf 16v if it looks puffed up on top it is bad ,you have 2 more caps to replace if cp150 is bad cp114 cp120 220uf 35v. and for convergence Try this with set off Press and hold vol- and ch- at same time untill set come on release now you should see service menu go convergence there reset defaults.
Posted on Dec 27, 2008
I need a convergence kit for a rca 52 inch rear projection tv
what type of problem with convergence? no convergence at all? pitcure bowing? this in the setup menu do you have the convergence option? a convergence ki in a standad porojection has stk ic/s this model does not .you might have the fl231 fuse problem.. generally its board replacement. then the problem becomes alighnment.
Aug 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My R52WH74YX66 HDTV shows in 3D and double vision
This is a common problem in these sets; if the set does not show "convergence" in the customer menu there are three pico type fuses on the deflection board and one is blown.
To be perfectly honest most shops do not like to fix this brand of set as the convergence circuit is spread across 3 circuit boards that are not available--all parts of course are RCA only and delays to get parts needed are common here.
Look in the customer menu and if convergence does not show, one of the protect fuses (really labeled as a "coil" is bad---these are usually located next to the High Voltage transformer and are usually tan in color about the size of a one watt resistor.
Let me know if you have questions as I am here to help.
SD TECH
Jul 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Convergence
if you cant converge from menu. your convergence ic is going bad.
Jun 02, 2009 | RCA R52WM24 52" HDTV Projection Television
Older RCA projection flickers and convergence out of whack
you can check the three little red fuses next to the flyback transformer , but then if not that then the convergence IC's will need to be replaced and the resistors checked on it for possible replacement
Jan 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't stay on
The first thing I would do is to check the solder connections on the flyback transformer. This is a common problem with this set
Dec 05, 2008 | RCA HD52W59 HDTV Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
225 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
