Question about i-mate K-jam Smartphone
Phone refuse to on after charging
I left my k-jam phone charging for over 3 hours with a motorola L6 USB charger,wen i woke up,it refuse to come on.there is no technical support in Nigeria
    Novelist:
    Scholar:
  • 111 Answers
Please my comment in your first listing. TRy everything one by one: 1) Test your Battery 2) Test your phone power plug 3) Open the phone to troubleshoot the mainboard Sometime, you may miss some small thing. Try to correct the small thing first but don't leave your phone for too long. Keep coming back in 15 minutes to see any progress. It may shows up the progress quite fast either bad or good.
Posted on Apr 07, 2007
L6 charging problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 11, 2010 | Motorola Mobility L6 Cellular Phone
I have the same problem but I can't enter the debug menu using
I have a Motorola RAZR V3x which has worked reliably for about 3 years. Very recently (having been recharged a couple of hours earlier & without any prior suggestion of impending battery failure), the phone has refused to turn on and attempts to charge it with the factory charger do not even light the blue charge indicator. An attempt to charge it through the computer's USB port lit the blue charge indicator for about 1 second but also failed to charge the battery.
Aug 19, 2009 | Motorola Mobility RAZR V3
Motorola L6 charging?
get the right charger because that charger is not the right one okay
Sep 16, 2008 | Motorola Mobility L6 Cellular Phone
Home Charger
do the chargers have the same pin or look the same?????
Mar 17, 2008 | Motorola Mobility L6 Cellular Phone
Probleme charge motorola l6
answers to ur questions
1.it is totally dependent on the charger.
2.yes it shows the charging
3.just cool
Feb 20, 2008 | Motorola Mobility RAZR V3
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
when i conect my motorola l6 to my computer it not conect and my computer don't know this usb
Feb 19, 2008 | Motorola Mobility L6 Cellular Phone
Motorola E680i not charging properly
charge port prob lo...just change new port or do it ur self
Feb 13, 2008 | Motorola Mobility E680 Handheld
L6 won't charge
If u r not able charge u r battery , than change the charger , contact motorola care center.my be u r not getting power supply in mobile
Oct 13, 2007 | Motorola Mobility L6 Cellular Phone
At first, when you plug the the chaeger in, you must see the led comes out. If it si not then the charger is not compatible. different voltage will not work. Second, if the led is on usually in red then you should ocme back in couple hours to check for any progress. Third, if nothing working, you now then thest to see whether your battery is dead. The way to test battery is take the battery off and plug the charger into your phone and turn it on. If your phone is on, then you need to replace the battery. If the phone is not even on, probably your main board has failed in power supply and may need to be replaced. So try one by one first to see whether you have missed something before you can make a decision that the problem is from your phone main board. Good Luck
Apr 06, 2007 | i-mate K-jam Smartphone
i-mate K-jam Smartphone Logo
66 people viewed this question
Top i-mate Computers & Internet Experts
Peter Dragonetti
Rick
Rick
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
