Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer wont aggitate or spin
The washing machine will fill with water and empty water but that is all.
  • jkas857 Dec 21, 2008
    Thanks so much. Would you know if this is expensive to have repaired?
  • Anonymous Mar 30, 2014
    will fill but wont turn to wash
    Novelist:
  • 161 Answers
I think this is the direct drive model, no belt. There is a coupling between the motor and transmission that needs to be replaced. This is a common problem with that type washer.
Posted on Dec 21, 2008
  • Ron Buice
    Ron Buice Dec 21, 2008
    If the tube has a hole you could patch it yourself. The switch is around $20-30.
Washer will not aggitate or empty
You have a bad lid switch. Here is that part to order.
There is also a video on that same page to show you how to make the repair.
Nov 15, 2013 | Amana NTW5400TQ Top Load Washer
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Washer will fill up lid switch clicks hear timer running and advances but will not aggitate spin or empty water
sound as though you have a wiring problem around the motor harness..Or you may have to cheak for current across the switch when you click it on and off.Hope i helped:)
Jan 24, 2010 | Maytag LAT3600A Top Load Washer
GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Mar 05, 2009 | GE WJSR1070A Top Load Washer
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
I Have the same problem! Please Help!
Try tipping the washer over forward and look to see if the belt is still in place. If so, make sure it is tight. Have you tried setting the control knob on the control panel ahead a click at a time manually?
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
186 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
