Question about Canon EOS-5D Digital Camera
Canon 5D RAW and JPG image problems
I record in raw and high quality jpeg. Suddenly, I am finding that occasionally in a shoot (5 out of 40 images), some of my raw and jpeg images have blank or grey areas. Is this a software problem or should I take it in to Canon repair?
  • 3 more comments
  • Feine Dec 22, 2008
    Dear Guru,
       I thought it was my memory card, but it did the same thing on 2 other cards. It is not the cards, as I reformat them every time I download their photos.
    Jocelyne
    It is not my memory card, since it occurred on all of them. In addition, I regularly reformat my cards after each download.
    The problem in my images does not look like the images shown on the noted website. In my images, half of the image is all grey. It can be one or another side, or the bottom or top half.
    The demarcation line between the image and grey area is distinct and straight.
    Anyway, I unfortunately have only the 5D and not the 5D Mark II, which is where the black dot problem seems to occur.
    The large gray areas appear in different spots. I have tried many different cards with the same result.
    So, I will take my camera to a service center.
    Many thanks, Jocelyne
  • 15,935 Answers
Canon is notorious for raw image problems. Is it the imaging software that has issues or the viewer on the camera?
It may need recalibration - where it will need to be sent in for repair.
Posted on Dec 22, 2008
  • Canon Master
  • 19,396 Answers
Hi there, this is not a memory card problem, in the best case a firmware fault, but very very unlikely, and it would affect only Jpeg, not RAW in this case.
When you get this problem , the CCD (or CMOS on other models) array sensor, that take the picture is defective, or the connection to board/ board itself has a fault.
If you get a problem only on JPEG instead, if some JPEG is scrambled from a point to the bottom of the picture, that is an onboard problem.
Do a reset to factory settings, from camera menu, just in case.
That will probably not work, in that case call support.
  • 3,037 Answers
Hello Feine
Try a different card in the camera first. Is this happening in the same spot on these pictures or in different spots?
If a different card doesn't work, take it to a service center as it isn't a software problem.
bestdarngood
    President:
  • 2,110 Answers
  • 10,594 Answers
Format memory card and try again.
its unbalanced memory card problem only. camera is just fine.
  • Shahid Electronics
    Shahid Electronics Dec 22, 2008
    OK, there is firmware update available on Canon Support for D5.
    I would suggest to update camera firmware from Canon Service only.
Can't remove the RAW Setting to keep just the JPEG option without RAW. It is set to RAW and the dial only scrolls through JPEG options. How do I get access to the RAW options to turn off RAW??
When on the image recording quality setting screen, use the main dial to select RAW (go all the way to the - sign on the left to turn off RAW), and use the multicontroller left/right to select JPEG settings. See page 116 in the manual.
Jun 20, 2015 | Canon EOS 70D Digital SLR Camera Body Kit,...
Setting cannon
When you choose quality L, but with the stairs logo, not the quarter circle, the fame size will be around 3.3 mb on average for the jpg files.
Only when you select RAW or RAW + JPEG you get the big files. (Up to 25 MB + 6 MB)
Everything about the image-recording quality settings can be found on page 61 of the manual.
Aug 17, 2014 | Canon EOS7D28135KT EOS 7D 18MP SLR Digital...
How do I stop the camera from having a double of every picture taken?
On my D-90, the camera is set by default to store two images of each picture I shoot...raw(NEF) and JPEG Fine.
The raw image contains far more data than the JPEG image and is therefore the best to use when you want to do extensive detailed editing.
The JPEG image is used when you only want to do minor editing before publishing or sharing the picture.
JPEG images deteriorate quickly when subjected to editing while RAW or NEF images can handle many more editing steps before losing quality.
If you're shooting snapshots, you probably don't really care about extensive editing and you can save a lot of space on your memory card by changing your menu settings to store only one image of each shot.
To do that, go to the wrench icon in the menu then scroll to image quality. Click on "image Quality" and you will find multiple lines to set the camera to your preference. Choose the one you want.
Apr 19, 2014 | Nikon D5000 Digital Camera
What does raw+fine pictures mean?
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
Apr 14, 2013 | Nikon DSLR D90 Digital Camera
Wehn I download my pictures to my computer I can not open about half of the pictures. Some say IMG-0099 (or what ever number), 3,888x2,592 JPEG Image 4.36 MG. These I can open. Others say IMG-0106 (or...
CR2 files are created when you shoot RAW files. Your computer cannot read them without a Canon RAW plugin in whatever image processing software you're using.
Your camera can be set to record in JPEG, RAW or JPEG and RAW.
If you wish to know more about RAW files and their uses, then click here.
I hope this has helped you, if not then please add a comment to explain what additional information you'd like regarding this problem but otherwise please take a moment to rate my answer.
Sep 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
When I shoot in Raw + jpeg, no raw filkes show up.
I had the same problem, basically all you need is a RAW converter, the canon software should do and should be provided with the camera and if you havent got that then there is a wide selection of free software on the internet im sure of it just search for it, or a lot easier not to use RAW in the first place...
Apr 17, 2010 | Canon EOS Rebel XSi Digital Camera
My canon EOS 40D with 18 - 55 IS , when continuous shooting mode is selected, slows down after taking 6 shots. However as per the spec its capable of taking 75 jpegs or 17 RAW images.Please resolve this...
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Jun 07, 2009 | Canon EOS 40D Digital Camera
How can i imorove the Image qualityt? My camera image size has always been set on 'large & fine' which tranlates into a 300dpi image when I open it in Photoshop. Suddenly, large and fine only puts out a...
Best qulity you can get with canon 350d is RAW format, but you cant shoot raw in automatic mode , when you switch camera to manual mode you will see raw option is enabled. if not JPEG (EXIF 2.21) - Fine will capture your images at 8MPX with 3456 x 2304 resolution.
Nov 21, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Canon EOS-5D Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
