Cannot connect to network
I hav ecreated a wifi network, my computer can identify the network, but cannot connect to it. Where can be a problem? I use encryption WPA-PSK just like it is described in comp's manual.
Thanks
the problem with my wifi was in MAC filter configuration.
Have a nice day :)
z_kovacova
Posted on Dec 22, 2008
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    I have a new psp and and to connect to the internet i need a ssid code but i didnt get one when i bought it
    A service set identifier (SSID) is a name that identifies the network. To connect to a wifi network with your PSP follow these steps:
    1. Flip the WLAN switch to 'ON'
    2. Select Network Setup from the main menu after that select the Network Settings
    3. Select Infrastructure mode > Create new connection
    4. Select Scan and choose your WiFi`s SSID (name)
    Mar 17, 2011 | Sony PlayStation Portable (PSP) Console
    How to connect new laptop to router
    Hello
    Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    Hope it helps, if so do rate the solution
    Good luck
    Dec 24, 2010 | Linksys Wireless-G WRT54G Router
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know to use wifi in LENOVO 3000 Y410
    Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Cannot connect to internet with konaki netbook
    How to Connect a Laptop to a Wireless Router Using a Windows Operating System
    Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    Dec 12, 2009 | Computers & Internet
    Using free wifi spots
    If your laptop has wifi enabled, and you go to a place where there is a hotspot, you right-click on the little wireless icon in the system tray and choose "view available wireless networks." If one shows up and you can identify it, choose it and then click "connect."
    But--beware--if you can't identify the network as being in the store/coffee house,etc where you are sitting, don't try to connect to it. This is an open invitation for identity thieves and other bad guys to get access to your computer.
    Feb 02, 2009 | Acer Aspire 3004LCi Notebook
    How do I receive the signal with another computer?
    Hi, I have given ya a link that will explain all... http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx www.microsoft.com/athome/moredone/wirelesssetup.mspx Basically you give the Wifi Router an SSID (Unique name, say, AlrenaWiFi... whatever ya like though) Then on the "Remote" if it isn't already, you activate, "Enable" the WiFi adapter... and when enabled, the adapter then "Detects" the (any) wifi signals, you are asked if you want to "Connect" choose YOUR wifi SSID (Name) click connect and you will Be done. Now, thats for an unsecured network, for a "Secure" network, one simply has to assign a "WEP Key" to each "end" as an extra step. This is all explained in the tutorials.
    Aug 28, 2007 | Linksys Wireless-G Broadband Router
    Computers & Internet Logo
    148 people viewed this question
    David Payne
    David Payne
