Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
Bought TV in DEC 04. In Jan 07 the TV would start, shut down, then restart repeatedly. Tech guy replaced the lamp. This fixed the start-up problem but created a blue ghost over the center section of the screen. I kept the old lamp and put it back in. The old lamp worked and the blue ghost went away. I said the problem was due to new lamp. The tech guy and Sony said that's not possible. He put a second new lamp in and it had the same blue ghost problem. Then I put the old lamp back in and the blue ghost went away. The tech guy said there is slight evidence of blue ghost at the bottom edge of the screen. My point is that's not objectionable. The tech guy says the light box has to be replaced. I say there is something wrong with the new lamps supplied by Sony. The tech guy says the new lamp is stronger and it magnifies a problem with the light box that allows the blue light to "leak thru" and show in areas where they should be no blue light. Does this make sense? I beleive Sony redesigned the lamp; it's a different part number. It's a stronger lamp that puts more stress on the light box and creates new repair problems for the TV. Anyone have any info to share? I plan to stay with the old lamp as long as I can. I can't figure out why the lamp didn't work properly before and is working fine now.
I hyad the same problem and took it to my local teck. It was the the "Balace". I think this is how it is spelled.
Posted on Jul 24, 2007
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Posted on Apr 27, 2007
SOURCE:
For a KDF-55WF655 SONY PROJECTOR TV, WHAT REPLACEMENT LAMP DO I NEED
Required lamp for Sony KDF-55WF655tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200
Thanks.
Nov 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
Suggestion:
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Jul 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
Feb 06, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue violet ghost
did you just replace your lamp? your balance is probably off.
Jan 31, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
339 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
