Question about One For All URC4220 Remote Control
Programing remotes to equipement
Need info. on how to program remote to operate eqipement
  • 30 Answers
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Switch ignition ON.
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Switch ignition OFF.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
  • Obtain all remote transmitters.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
on Mar 26, 2015 | Televison & Video
Does anyone know what the universal remote control code for the Dion Digital set top box? (Model STB2AW09)
Try AK59-00104R. The Samsung AK59-00104R full-function or Universal remote control to operate varios devices and you can program the remote control to operate most of the popular brands of audio/video equipment like a TV, a DVD player (or VCR), or a Network satellite receiver. See Programming for Other Equipment on This remote control may have features not used by your receiver.
http://www.directutor.com/sites/directutor6/files/RemoteManual/AK59-00104R.pdf
Sep 23, 2011 | Samsung TV Set Top Box Remote Control
I need to reprogram the remote. Purchased a floor model Panasonic SC-PT480 and the remote is not fully synched with the player (controls on/off and volume only). How can I reprogram the remote?
The remote cannot be reprogrammed to operate the SC-HT70 as all functions are already set. If your remote isn't operating your equipment as expected then the chances are the remote has become faulty.
The remote can be programmed to operate other equipment as detailed on Page 42 of the manual below.
http://service.us.panasonic.com/OPERMANPDF/SCHT70.PDF
May 01, 2011 | Panasonic SC-HT70 System
How do you set the TV code for the remote: RMT-B107A
How to Program the RMT-B107A Remote Control:
Follow these steps to program the remote control to operate a television.
1) Turn on the TV.
2) On the remote control, press and hold the TV I/O button.
3) While holding the TV I/O button, enter the manufacturer's code using the numeric buttons.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
4) Release the TV I/O button.
5) Point the remote control at the TV.
6) Press the TV I/O button to verify operation.
NOTES:
If a new code number is entered, the code number previously entered will be erased.
When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
The operation of a combination deck of any kind is not guaranteed.
Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
Mar 16, 2010 | Sony Televison & Video
My Sony remote is RM-YD024 - I am trying to find the code for a Denon DVD player, Norm.
Here are all the codes for your Denon DVD player.
30490, 30634, 31634
Just in case you don't have the manual I also included the steps to input the codes.
Hope this helps
Follow these steps to program the remote control.
NOTE: Even though the FUNCTION buttons are labeled for specific components, they can be programmed to operate any type of equipment that is compatible with this remote control. For example, the BD/DVD function can be programmed to operate a VCR, AV receiver, etc.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the INPUT button.
  3. While holding INPUT button, press the FUNCTION button for the desired component.
  4. Release both buttons.
  5. NOTE: The FUNCTION button will blink for approximately 30 seconds or until a code is entered.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  8. Press the ENT button.
  9. NOTE: The FUNCTION will blink twice if the programming is successful, if not, it will blink five times.
  10. Point the remote control at the component.
  11. Press the component POWER button to verify operation.
NOTES:
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, use the remote control that was provided with the equipment or purchase a universal remote control that has a learning function.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
Nov 04, 2009 | Sony Televison & Video
Brand new dishnetwork 622 DVR UHF remote does not work
Contact Dish Network tech support. If they can not fix it for you over the phone then they will send you a free replacement. Hope this helps.
Apr 01, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Needcodes for yamaha receiver and steps to program for rm-302
102, 014, 030, 046 here are some directions Follow these steps to program the remote control.
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
  • The operation of a combination deck of any kind is not guaranteed.
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
try this link for any other codes you might need http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
Dec 09, 2008 | Sony RM-V302 Remote Control
Codes
try the following codes until one of them work:
002, 003, 004, 005, 006, 007, 008, 044, 045, 046, 053
  2. On the remote control, press the SET button.
  3. Press the appropriate component button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
NOTES:
Nov 23, 2008 | Sony RM-V310 Remote Control
I cant program my universal remote to my coby dvd player model 514
need more info. make and model of universal remote? can you program the remote to other equipment? are there codes in the manual for coby dvd player?
Jul 30, 2008 | Coby Televison & Video
One For All URC4220 Remote Control Logo
41 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
