Question about Epson Stylus Photo R220 InkJet Printer
Inaccurate color printed
I have the Epson Stylus Photo R200 that is printing pink instead of orange even though the cartridges are half full.
  • pgvince789 Jan 02, 2009
    Yes I have the same problem. I am using non-standard ink cartridges. It is not set to draft mode
    Problem Solver:
  • 9 Answers
Check the color profile settings for your printer. Also, make sure your not using any kind of draft mode. Are you using refilled cartridges or off-brand ink?
Posted on Dec 21, 2008
My espson R200 won't print black even though it is full :s
> ESPSON
ESP-son? EPSN-Sports-Online?
Use the EPSON software to run a "print-head-cleaning" cycle to try to "unclog" the path that the ink takes from the ink-cartridge, through the "jets" onto the paper.
Nov 17, 2010 | Epson Stylus Photo R200 InkJet Printer
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
I have an Epson Stylus Photo R200 that will not print
i am not sure where you are leading, but I assume you want to print with the black without changing the colors. No, you are not able to do that. If the colors require replacement, you have to change them before you can continue to print.
thanks
Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Printing problem
Try jiggling the cables and making sure that the USB connection is solid. It worked for me. Good luck.
Sep 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - Solid Red Light and printer not working
printer cartridge chnaged again red light pinking not printing pls give me solution
Jan 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R320
When you run the nozzel check, do each of the colors print out right, or just the magenta ones?
Oct 28, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
257 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
