I cant send or recieve text was told to find service centre in the menu but cant find it
SOURCE: Cannot send text messages, requests service centre
This is something you need to call your phone company about. Only they have the Service Center Number. Sorry your having problems with your device, hope i've helped.
SOURCE: When ever I get a
Hotline support is available for your phone at
http://www.htc.com/us/support/hotline
thank You for using FixYa.
SOURCE: I have an HTC touch2.
The problem is from the message center number, you will need to check it for right message center number. From the menu on your phone, go to message, from message go to setting, next
to message center to check if the message center number is correct. the
way you can no if the message center is correct is to compare it with a friend phone that uses the same network as yours using the same network as yours.
If after making comparison with your friends number, set it to the real message center number, your text messages will start sending. You can also call you network service provider to get the message center number.
SOURCE: can not send text messages, but can recieve them
My Dear :
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Problems sending or receiving SMS may be caused by no or incorrect SMS settings. To set up your phone to use SMS, you need a message centre number, which is provided by your network operator. This is often set up automatically when inserting a new SIM card to a phone. Whiteout the message centre number, you are not able to send or receive SMS.
To edit the service centre number:
To add a service centre number provided by your network operator:
