Just finished installing a KN8-SLI, with 2 bridged GeForce 6800 GPUs, checked and double checked all power and hardware connections, checked them again, turned the power source on, bot the expected leds on the board then hit power switch, got no display, get a constant intermittent beep, every second or so, ongoing. Tried pulling memory, disconnected the RAM, disconnected DVD & CD drives, floppy drive, and tried restart with every removal. CLeared CMOS (recommended by ABIT) at the beginning of all this after the first failed start. Started out with a AMD Athlon 64, then switched to a Sempron 3400 that wa son the board when I got it, no difference. Not many other ideas... can you help???
Hi
i had a pc to repair last wek for a friend and it to did beps, I found after testing the motherboard and memory it was the graphics card and Not the memory as thought.
If I can help please fel fre to email Me below
Best regards
John
[email protected]
Sounds like a bad or wrong stick of memory
that shoul tell you something, the mmemory in and out gives you the same error, means the memory is bad, it should have given you a different code, ok try thismove the memory to each slot and try to boot, sometimes a board will specufy which motherboard msmory slot needs to be used first, and try a stick or different memory, it should have given you a different code with no mem at all, it's not reading it.
Some boards only like certain ram also depending if it is running only in dual channel it may need to be set for that see in the bios what it loos like and send me a link with a screen shot if you can, but your on the right track, once this grts running right i'm counting on you to give me 4 intead of 2 stars, I just fixed another sli for a guy who works on computers for a living in here. we will get it. Put the big dual core in and clear the cmos, be back to you later, Gym, hesr's a hotmail address georgeburns723@ you know what to put afterthe @.
thanks
Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disk the drivers could be on it or you might have to download one
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html This package consists of SiS VGA Drivers, AGP Drivers, VGA Utilities, and Installation for Windows 7. Utilities include Control Center and SiStray. The Control Center provide some settings like gamma correction, video, TV output, driver mode, screen rotate, and product information. The SiStray provide Control Center entery and some settings like resolution, refresh rate,and rotation. The Installation are capable of installing/uninstalling drivers and utilities respectively.
Supported Chipsets:
SiS671, SiS672, SiS671FX, SiS672FX, SiSM671, SiSM671MX, SiSM672, SiSM672MX hope this helps cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
or
Windows 7 32 bit
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs.
What's new in this version:
Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs
Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers
Adds NVIDIA Update feature
Windows 7 64 bit
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html
hope this helps you
you cant have lose your graphics card just need to update the drivers
Supported Chipsets:
or
Windows 7 32 bit
Windows 7 64 bit
hope this helps you
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630932.htmlI Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
http://download.cnet.com/nvidia-graphics-driver-windows/3000-2108_4-10630939.html Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs.What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature hope this helps
insert the card into the pci slot on you motherboard turn your computer on the found new hardware should activate and ask you to install the drivers/software for it
if you need more help with this post a reply
hope this helps you
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What's new in this version: Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUsIncreases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers Adds NVIDIA Update feature
display card not compatible or the drivers not compatible??
Supported Chipsets:
or
Windows 7 32 bit
Windows 7 64 bit
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don
Supported Chipsets:
or
Windows 7 32 bit
Windows 7 64 bit
http://majorgeeks.com/Nvidia_Forceware_for_Windows_VistaWin_7_d5935.html
This is the first WHQL-certified release from the Release 275 family of drivers (versions 275.xx to 279.xx). This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400,
and 500-series desktop GPUs as well as ION desktop GPUs
hope this helps you
Supported Chipsets:
or
Windows 7 32 bit
Windows 7 64 bit
hope this helps
This is the first WHQL-certified release from the Release 275 family of drivers (versions 275.xx to 279.xx). This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs
Click
If
Supported Chipsets:
or
Windows 7 32 bit
This is a WHQL
desktop GPUs.
What's new in this
version:
Windows 7 64 bit
This is a WHQL
desktop GPUs.
What's new in this
version:
hope this helps
I tried it without ANY memory installed, same problem
so... if the memory is bad and I get a beeping, but then I start with no memory at all, and still get the same beeping, how could it possibly be the memory, since it is not in there to give me any error on any particular stick??? It has to be something else in what is installed giving the same error, regardless of memory installation (I have 4 1G sticks, tried them all , in various config's, no dice!). I Have been reading and reading and saw something about the ATX power being 20 pin vs 24 pin. The board has 24, and the power source has 24, along with the 4 pin with 2 yel, 2 blk wires. Is it possible the power source (Coolmax CXI-500B) is incompatible with this board, or bad?
OK... I tried differnet sticks in different slots and I guess I never had tried 3 and 4, but when I did, I can get into BIOS now... yay!...? We'll see how much further I get. So now my question is, this thing has 4 DIMM slots, but can only go up to 2 GB??? I have 4 identical sticks of 1gb 400ddr, but only 2 work. Is there anything I can do to expand to the supposed 4GB max?
I am into BIOS and loading WinXp Pro now, but have a whole new prob, which I will post separately as "Unable to read disk or disk error, press ctrl+alt+del to restart"
. . . . Just a note to wrap this one up. . . . One of 4 sticks of RAM I had was BAD. I tried several different combinations and isolated the one bad stick, sent it back and they are sending me a new pair...
