Question about Reddy Heater R70 Portable Forced Air Space Heater - 70,000 BTU
Won't stay running
I can only keep it running with the cover off
  • Paul Bede Dec 01, 2008
    I have the same problem, will only fire if cover is off, I tried jumping the cad cell and no difference.
  • dadiekman Dec 23, 2008
    I have maybe the sae issue, it will tart fr about 20 second and die alng with flipping the breaker ?? Help please. It kerosean
  • 625 Answers
Is this kerosene or propane. if kerosene, two types of ignition is used.  a spark plug or a hot surface ignitor.  the kero unit uses a cad cell flame detector, the propane unit uses a millivolt generator.
the kero unit uses an air pump that comes off the backside of the fan motor - this airline goes to the nozzle and acts like a siphon for fuel.  there is no air pump for the propane heater. the fan just accelerates airflow through the combustion chamber.  the cad cell of the kero unit sees the flame and varies its resistance.  it is sensitive to the infrared generated by the flame and feeds this signal to the lockout relay. no flame after a few seconds, opens and locks out the unit.  the propane unit uses a millivolt generator.  it is a copper cappillary tube that has two spade connectors on it. the spade connectors are connected to a high limit mounted on the backside of the combustion chamber.  under normal conditions the hi limit is closed and completes the electrical circuit to the main valve. the millivolt generator is electrically connected to the pilot/main valve electromagnet inside. with a flame detect signal the electromagnet is energized and holds the main valve slug open allowing the propane to feed to its nozzle in the chamber. as long as there is a flame the valve stays open. no flame, no signal and the unit releases the valve pellet and closes.  you can test the hi limit by jumping out the two spade connectors and see if the unit starts and stays running.won't stay running - da8a32c.jpg
Posted on Oct 15, 2007
Car won't stay running
You can use code scanner to check the engine system first.
Jun 20, 2013 | 1997 Pontiac Grand Am
2003 Dodge Durango (5.9L V8) won't stay running unless you keep your foot on the gas.
Check temp sensor and TPS, throttle positioning sensor.The power control module,"pcm.is a possible thought.Just check all connections. It is always a good idea to spray WD 40 or equivalent in the connections.
Feb 11, 2013 | 2003 Dodge Durango
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Aug 15, 2017 | 1998 Ford Expedition
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
Replaced timing chain an it starts but won't stay
does it run ok or is it misfiring ? why did you change the chain
Dec 11, 2011 | 1987 Oldsmobile Delta 88
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
Aug 27, 2017 | 1998 Jeep Grand Cherokee
Won`t stay running after it warms up not overheating
is it carb, or efi ? and what size engin?
May 30, 2009 | 1985 Ford F 250
Replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Jan 20, 2009 | 1997 Dodge Dakota
Heating & Cooling Logo
818 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
