Question about Nintendo Wii Fit for Wii
Power to wii console disrupted
Used wii successfully for a year now. Within the first hour of using the balance board the power suddenly went off on the main console and the board. Power resumed on the board immediately after pressing the 'on' button but power has not returned to the main unit. Power still not returned to the unit after 30 mins now and the clock is still ticking.
  • robert17 Dec 21, 2008
    Thanks to FixYa expert on 21 Dec (sorry I forgot the nickname) - I just unplugged the power from the wall unit for 3 mins and works perfectly
Simply removed the plug from the wall socket (left all other connections intact) and waited 3 mins then replaced the plug into the wall socket. Bingo! Light appeared and pressed the power button on the unit. Very happy to FixYa (cannot recall the member's name) for the solution.
Posted on Dec 23, 2008
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
Mar 03, 2011 | Nintendo Wii Console
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Mar 18, 2010 | Nintendo Wii Fit - Balance Board + Game...
Balance board on wii fit doesn't turn on? power light flashes
All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
Oct 17, 2009 | Nintendo Video Game Consoles & Games
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Power led light
If there is no reason for the Wii Balance Board to be on, it will automatically turn off. Start up a game that uses the Balance (Wii Fit) and it will tell you when to turn on the Wii Balance Board. If you still have problems, try to sync the Balance Board again.
Aug 29, 2008 | Nintendo Wii Console
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
