Question about Kitchen Ranges
Regal Automatic Breadmaker model 6783. The seal for the mixer shaft in the bread pan is repped and need to be repaired. Do you have a new repair seal. This particular seal assembly is made of rubber and includes a coiled retainer ring that holds it firmly around the shaft. Please reply regarding availablity and a price. Thanks, Bill at menb89@msn.com
SOURCE: Re Smeg 60cm electric
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Posted on Sep 20, 2008
SOURCE: need parts for Breville modelBB200
I need parts and cant get them anymore, machine is obsolete. Thanks
Posted on Jan 18, 2009
milten1
  • 1304 Answers
SOURCE: the sealed burner when cleaning around it had a
this is a water gasket
you can repair it pretty easy just find a rubber band that will fit
Posted on Oct 07, 2009
Daniel S
  • 4323 Answers
SOURCE: I need a new hose
Hi
Please click on the below links to check for the parts for your Philips vacuum cleaner--
Philips Vacuum Parts link
Philips Vacuum Parts link 2
Hope this helps...
Daniel
Posted on Aug 07, 2010
tunde007
  • 2382 Answers
SOURCE: Hi, My Frigidaire Clothes Washer,
Hi, what you are experiencing is problem with the Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
You can get the parts by contacting appliance help on 1-800-470-7119
Posted on Oct 06, 2010
I need a bread pan sealing kit for my BR1 breadmaker
I'de give
http://stores.ebay.com.au/Bread-Machine-Parts-Finder/Breville-Breadmaker-Parts-/_i.html?_fsub=1744776014
a go and or look in telephone /online for Repairers/Spare Parts Sellers/Stockists in your country.
Good Luck.
Nov 02, 2014 | Kitchen Appliances - Others
Kneading blade for model k6774
I have a paddle for a Regal k6730 that might fit. If you can send be a good clear digital pic of the spindle in the bottom of the pan. I can probably tell if they are the same. email the photo to dary441@msn.com and we can go from there
Nov 28, 2012 | Regal Ware K6725 Kitchen Pro Bread Maker
The rubber (?) gasket between the kneading blade and the bottom of the bread pan has deteriorated and sluffed off into bread. Can I get a replacement?
Hi, That is actually a sealed bearing that the paddle shaft rotates on. It can not be replaced and you will need a new bread pan. Regal does not make bread machines anymore, but you may find one on eBay or Amazon. Hank
Dec 05, 2010 | Regal Ware Kitchen Appliances - Others
My Regal breadmaker has begun to release a black greasy substance into my bread dough. Do I need to replace the pan?
The black substance is lubrication oil. The oil lubricates the bearing and shaft that the paddle spins on. Usually this bearing is sealed, but black greasy substance means that the seal is broken and is leaking. Just a matter of time until it fails all together. Time to replace.
Hank
Nov 05, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
KENMORE AUTOMATIC BREADMAKER - REPAIR
I prchased a ice cream maker at a yard sale the mixer blade would not turn so i put some hot water in the machine and let it stand and it worked some ice cream had dryed around the shaft
Dec 12, 2008 | Black & Decker B1561 Bread Maker
Regal breadmaker manuel for 6783
go to http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Oct 14, 2008 | Kitchen Appliances - Others
My automatic breadmaker Model 48480 just wouldn't work today. I believe it's because the paddle under the bread pan was stuck which forced the machine and damaged it. What can I do to repair it.
Thank you
Peter Liu
Mar 21, 2008 | Kitchen Appliances - Others
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
