Question about Sony KP-61HS10 61" Rear Projection Television
TV has panaramic view
The exact model number is KP-61 HS30.
  • 3 more comments
  • Ken Mangione Dec 22, 2008
    I have found Ckt Board "D" but can not find IC 8001 or IC8002. I found the fuses and they are good.
  • Ken Mangione Dec 23, 2008
    I can not find IC 8001 or IC 8002. I looked to see if they were mounted on the silver heat sink and there is nothing mounted on it. All that I have found was C and i'm guessing that C stands for capasitor, but have not found anything labeled IC. I have see a big black piece mounted on the board, there are two red wires that come out of it and runs to a different part of the TV.
  • Ken Mangione Jan 13, 2009
    I have just changed IC 8001 and 8002 like you have asked. The TV still has the panaramic veiw. Is there any other ideas? I was ESD safe while solding, and use a magnified glass to make sure that i didn't have any solder runs. Any more help would be great.
    Can you supply a picture of the Pico Fuses?
    I have found the PS's that you are talking about. How do you check them to make sure that they are good? If need to replace can you tell me a good store to purchase with part number.
  • 10,594 Answers
I just replied your question. You can see it by clicking HERE.
Posted on Dec 21, 2008
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Dec 22, 2008
    IC8001 and IC8002 are big black ICs and mounted on Silver Heat Sink.
    Shahid Electronics Dec 24, 2008
    IC8001 and IC8002 look like below image...
    Shahid Electronics Jan 13, 2009
    There are 6 pico fises near above ICs and these fuses should be checked. Fuses are numbered as PS8001 to PS8006
    Shahid Electronics Jan 14, 2009
    Best was to test PS is at least one pin should be out of circuit and PS should have no resistance (0 ohms)
    pico fuse would be available in Part Store.
Hi i have a sony kp-61v75 and there is little white lines all across the screen what could this be
The problem might be with its video output voltage. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | Sony KP-61V75 61" Rear Projection...
I have a Samsung 61' but for some reason the view
it depends on what model number is---some of the older sets have lens that require cleaning(pretty easy) and to help I need to know the model number.
Mar 19, 2012 | Samsung Televison & Video
Q8013&q8014 part number
In Sony KP-51WS500 model, I could find only Q8014 transistor and part number is as follows..
Q8014.. 8-729-120-28.. TRANSISTOR 2SC2412K-T-146-QR
Let me know exact model number of TV to find out Q8013 and 8014 part numbers.
Oct 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Need blue tube for sony 61" kp-61s70
Heres a link to where you should be able to get a used Tube for your model you can leave them a email with your model number and what youre needing and they respond quickly.
http://servicemanuals.vstore.ca/
Jun 14, 2009 | Sony KP-61S70 61" Rear Projection...
TV has panaramic view/ 3D view.
Symptoms shows its problem of failure of convergence out ICs on D board.
Find IC8001 and IC8002 on D board and replace them as per following part number...
8-749-019-08 STK392-560
You also need to check following pico fuse PS8001 to PS8006 (6 fuses) as few can be blown off and requires replacement.
You should do above said repair if you have knowledge of electronics, have experience of big TV repair, have necessary tools and know that electric shock risk is involve in TV repair.
Let me know if you need further help.
Good luck.
Dec 21, 2008 | Sony KP-61HS30 TV
Color yokes for KP-53XBR45
1-451-441-11 for the Red and Green tubes
1-451-441-21 for the Blue
Dec 19, 2008 | Sony KP-61V90 61" Rear Projection...
I have a old 61 inch tv the lens are out. Are these lens still available numbers on them are 646376-1 delta 24 passed 08121490 by U S Precision Lens inc Cinn. Oh.
The lens isnt the problem the tubes(CRTs) are what go bad. Whats your model number I may be able to help you out. The other site I work at has a huge inventory of used picture tubes that are all in good working order. Finding new tubes for anything older than 97 models is almost impossible. But post your model number and I should be able to help you out.
Apr 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Replacement lamp/bulb sony kp-61hs10
that model number doesn't use lamps it uses cathode ray tubes projection tubes. the CRTs for that tv are probably no longer available.
Feb 22, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony projection tv model kp-61v90
possible power supply or short on the b+ run,check for shorted horiz. o/p tranistor.
Aug 31, 2007 | Sony KP-61V90 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
