Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit D41 lights 1 & 2 flashing
Have removed the base plate and there is no sign of water so i removed the exhaust pump which was fine and rotor moves freely,yet when starting machine it empties and starts new cycle heating up before stopping with lights 1&2 flashing.any ideas?
  • markgoodison Dec 26, 2008
    I tried this and the pipe was clear,i have tried filling the machine manually and i am still having the same problem.Where next?
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Posted on Dec 22, 2008
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Our dishwasher idl 40 indesit has 1 and 3 flashing lights on the panel seems to be a problem
I have had this problem also and no longer take anything apart take out the filter plate pour boiling water into the well leave for 20 mins put on a 25 min fast wash and hey presto works every time. Mine seems to block up about every 4 weeks and the lights come on but this solution always works
Mar 06, 2012 | Indesit 18 in. D41 Slim-Line Free-standing...
D41 Model. Switch on, small beep, pump starts, small beep, first green light flashes, no water enters the machine
Check that the water is turned on. There may be a fitting with a screw driver slot in it. This slot shows the direct of the hole that lets the water through and therefore it should be lined up with the pipe direction.
If it isn't turn it through 90 degrees.
Feb 18, 2010 | Indesit 18 in. D41 Slim-Line Free-standing...
Ist GREEN LIGHT FLASHES BUT WONT FILL WITH WATER
I also had this problem, it was the automatic anti-flood device, the upper spray arm water pie was leaking into base off unit which operated the anti-flood device.
Hope this is of some use to you and others
ipip32
Jul 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Lights keep flashing
Have you have checked the waste pipe is not kinked and raised to about level with the top of the machine? If you have checked these things it could be the waste pump located at the rear right corner in the base of the unit.
To acess the pump tilt the machine to 45degrees and remove the base plate(6 screws) remove the two wires from the float(brown and pink) and move the plate out of your way.In the rear right corner you will see the waste pump.remove the pump and check the impelor is turning freely.If not dissmantle the pump(3 screws)and carefully remove any debris.Re-assemble.good luck.
Dec 08, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Machine not pumping out
blocked pipes or no power to pump, check in that order, but clean any filters out first, cheers
Jul 05, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
hello mate, i bought a brand new indesit d40. plumbed it in and the 1st light kept flashing, phoned the technical centre and they said its the anti flood mechanism kicking in and preventing it from working. although water was going in it was not going into the dishwasher but filling the base and the safety feature just shut it off. said to get back in touch with comet who i bought it off for a new one because its a manufacturing problem. put the new one in and theres no problem. wouldn't have a clue how to fix it myself though.
Apr 06, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
751 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
