Question about RCA M4208 MP3 Player
PC WON'T RECOGNIZE MY OPAL RCA M4208RD-8
I KEEP ON PLUGING MY MP3 TO THE PC AND IT WON'T READ IT
  • 5 more comments
  • iixtreme
    iixtreme Dec 22, 2008
    It started out that i would just say Initializing on the player's screen, but now it does not work at all.
  • Anonymous Dec 22, 2008
    It started out that i would just say Initializing on the player's screen, but now it does not work at all. please help ....fix me
  • res_1991 Dec 25, 2008
    mine worked fine for a couple hours..then I turned it off and when i turned it back on its stuck on intializing and won't do anything else..my computer won't even recognize it.
  • Anonymous Dec 28, 2008
    I have the same problem!!!!!!!!
  • efgleft Dec 29, 2008
    pc wont recognize and my opal is frozen at initializing prompt
  • beecharmer67 Dec 31, 2008
    I tried it and it didn't help me either. Thanks for trying!
  • muztangj Feb 14, 2009
    My PC does not reconize the mp3 and the it does not turn on
I got help from someone on this site that helped me fix my player. What you need to do (or what I did) is delete all of the RCA files from your computer completely. Then download the firmware upgrade from the RCA website (www.rcaaudiovideo.com) Once you finish that download, make sure that the player is not connected to your computer. Begin to press both the "Play" and the volume + buttons at the same time and then plug it into your computer. Then start the firmware updater at the same time; eventually, your computer will see that your player is there and that is basically all that I did.
Posted on Jan 12, 2009
The pins in the connector get pushed down over time and need a boost up. In the end if you look and see some gold dots. those are the pins that the cable contacts with. push them in, very little effort is needed. You can use a thumb tack. Give it a try.
Posted on Dec 08, 2009
    Problem Solver:
  • 7 Answers
This is what the Audiovox website sent me, but I had no success, maybe you can get some help from it.
1. Download firmware upgrade (I have attached the firmware update software to this message. You must log in first to access it. In order to download the firmware updater software, you must first log in for access. After you have logged in please click on the “My Stuff” tab, then select the “Questions” tab, there you will find the reply to your incident with the software attached at the bottom.)
2. Hold play/pause button for 15 seconds
3. Hold menu button for 10 seconds
4. Attach your Opal player to the PC via USB cable while holding play/pause button
5. This should start the firmware upgrade (While the firmware updater is running, if the player is not recognized or the firmware updater does not start, disconnect the player but do NOT close the updater. Now reconnect the player to the PC while holding the play/pause button. This should start the updater and place an icon under My computer for the player.)
6. Possible an error message of “cant write to disk” will pop up
7. Firmware upgrade will end with error do not close
8. Go to My Computer find the drive that holds the MP3 player
9. Right click scroll down to format, format the player
10. Run firmware upgrade again
Posted on Dec 27, 2008
Frozen screen RCA M4208RD-B (OPAL logo +word "Intializing")
Try to charge it for at least 8 hours, and also try this website:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2200
Aug 22, 2009 | RCA M4208 MP3 Player
Firmware for my rca opal m4208rd
This is a very common problem with the RCA Opal.
You need to goto the RCA website and download the latest firmware.
http://www.rcaaudiovideo.com/product.aspx?product=408
Download the firmware from there. Plug in your mp3 player. (don't worry if it cant be found bye the PC it will when the firmware installs)
After the mp3 player is plugged into the usb device of your pc install the newly downloaded firmware. And it should work fine.
Jan 27, 2009 | RCA M4208 MP3 Player
I have an RCA mp3 player model # m4208RD-B and it will not turn on, pc does not recognize it I only used it once.
control panel
add hardware
connect your hardware device and click "yes i have connected the hardware"
scroll down and select install new hardware device
select install hardware that i manually select from a list
scroll down to windows portable devices
and choose MTP device
Jan 16, 2009 | RCA M4208 MP3 Player
Cant find the reset switch
If it's anything like the opal M4002 then on the back of the player there will be a small hole into which you can insert a small implement (like a toothpick) and press the reset button.
Jan 14, 2009 | RCA M4208 MP3 Player
After a firmware update my RCA M4208RD-B won't work.
Download the firmware again.
after its download get the firmware you just download and install that one. Make sure mp3 player is hooked to your pc.
Go to add hardware.
Have windows look for MTP device. while the firmware is installing.
after its installed leave it hooked to pc for about 1 hour to give it a little charge. You should see a new folder Opal.
Let me know if that helped
Jan 10, 2009 | RCA M4208 MP3 Player
I got a RCA M4208RD-B MP3 playe and it is stuck on initializing.
I have the same make and brand.
Here is a link to the website.
You download the easy rip firmware and manuals there.
Jan 04, 2009 | RCA Audio Players & Recorders
RCA M4208RD-B MP3 Easy Rip software issues
Turn your player on and go to settings. Scroll down the menu until you see "PROTOCOL" and switch it from MSC to MTP. Your computer will now recognize your device, and you will be able to add whatever you want to it.
Dec 26, 2008 | RCA M4208 MP3 Player
MY COMPUTER WANT RECOGNIZE MY RCA OPAL MP3 PLAYER
One solution is this. Keep the Opal plugged into the usb and reboot. I did that and only then did it recognize my player.
Jun 29, 2008 | RCA M4004 MP3 Player
Rca opal
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Feb 19, 2008 | RCA OPAL M4001 MP3 Player
Rca opal m4018a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 02, 2008 | RCA OPAL M4001 MP3 Player
RCA M4208  MP3 Player Logo
893 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
