Question about Gemini Audio Players & Recorders
Gemini 676 pro platinum hum on right channel
This mixer has been fine until today, when i switched on there is a hum on the right channel, this is even with no leads except power lead plugged in. It cane be heard through the headphones. this hum seems to get quieter if you increase the cue volume. however the right channel l.e.d display has 2 leds lit constantly whilst the left channel has none.
aceltix
  • 119 Answers
SOURCE: MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Posted on Feb 08, 2008
SOURCE: On/Off not lit when plugged in
There is help for this in the user manual. Possible solutions I would try:
1. Make sure your source sound (TV, amp etc) is up high enough - if the sound is too low the headphones won't detect a signal.
2. Try changing the channel (the switch on the bottom left of the cradle base) and pressing the "Tune" button on your headphones. Try all three positions, pressing "Tune" at least 3 times in each position.
3. Take out batteries & turn off base, leave for 30 secs, reassamble and try step 2 again.
Should all work ok. I've been using mine for over a year and they're great!
Posted on Feb 21, 2008
SOURCE: The footswitch for bugera 6262
Hi ! Check and make shure that the cord conections between the pc board on the backplate of the amp to the logic board are firmly pushed in there slots.
Good luck , Stefan from Sweden
Posted on Jan 05, 2009
Witchunter
  • 98 Answers
SOURCE: KM18G pro motherboard power connection, reset sw, power sw, etc.
Hi.
You can download the manual for your motherboard here.
Inside you will find information of where does each connector go. Each connector on the case has a marking on it (HDD, PWR, RST or similar) which stands for hard disk LED, power button, reset button and so on. Connect it to the right place, and problem is solved.
If you need any further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Posted on Jan 18, 2009
  • 20 Answers
SOURCE: No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Posted on Apr 07, 2009
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
How do I open my mixer to repair the mic input jack
Gemini mixers are a hassle. You should take out all the phillips screws on the front, see if there4 are any on the side panels, and then see if it comes apart. If not, go for the screws on the back panel (the side and front /back ones). Be careful not to take out the one for the transformer (usually a big one or a nut). Peace.
Jun 09, 2015 | Gemini DJ Gemini MM-2400 4-Channel Stereo...
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
Why mixer turns on but no sound come out, just a weird interfearance noise any ideas?
Be sure the inputs are OK and the amplifier is also working. It is probably the internal power supply but that is just a best guest.
Jul 22, 2014 | Gemini DJ Gemini PS2 2-Channel Stereo DJ...
Clip light on Multimix 12 Firewire always on
I have just gotten the same problem. In my case it worked fine for almost three years and one today I turned it on and this loud humming noise + the red clip light always on appeared. When I hit solo button on channels 9-16 the humming disappeares but the light would not go away. With solo on humming get louder on the mic channels individually (1-8). I am puzzled... No solution so far
Sep 27, 2009 | Alesis Multimix 8 USB 8-Channel Mixer...
Gemini tt02 no sound!
phono \line switch the right way maybe.have you got signal on the mixer from dodgy deck
Aug 20, 2008 | Philips gemini TT-02 Turntable
145 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Don Hart
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
