Question about Samsung HCL4715W 47" Rear Projection Television
Convergence Hi.. I installed a new convergence board..AA95-01799G sent by samsung being careful to cause no static discharge.. The convergence adjustment states that sensors are attached to the center of each side of the convergence mode pattern, and the sensors are required for pefect focus function.. The manual asks i use a screen jig ?.. It also asks that i make sure the deflection yoke are properly adjusted so that the center of the green red blue pattern is aligned on the center of the screen jig?.. I see nothing in the manual about adjusting the deflection yoke. (question #1).. on the convergence mode pattern should i see the sensors?.. (question #2) how do you apply the screen jig to adjust the convergence?.. (question #3 is it necessary for me to adjust this yoke?).. however i warmed up the tv and connected an av source. did nothing with the deflection yoke.. i entered the convergence mode.. the osd displayed did not show any sensors.. the green and blue pattern are bowed inward.. i can adjust left to right on these but not up and down to straighten the bow? the red is perfectly straight.. i did try perfect focus after alignining the best i could and no sensor data displayed? please help me with the knowledge you have i seem to be close.. not there yet.. thank you again for your time and patience!.. sincerely tim.
  • 29 Answers
Im trying to install that same board on the same tv how did you do it?
Posted on Aug 12, 2007
    Problem Solver:
I just replaced my PCB SUB also. But cannot get perfect focus to work "No Sensor Data". Picture is slightly blurry and colors are off. I does look like the convegence is slightly off in the "Convergence Mode." Did you have any luck?
Posted on Aug 26, 2007
SOURCE:
My maxent mx50hpt52 in picture is very faint what would cause this and how do i fix it
HI; MOST LIKELY CAUSE IS "Y SUSTAIN" BOARD. TRY TO FIND ONE ON EBAY. IF ATTEMPTING TO FIX THIS YOURSELF, BE VERY CAREFULL TO MAKE SURE THE POWER SUPPLY IS COMPLETELY DRAINED BEFORE REMOVING BOARD. ALSO, WHEN INSTALLING NEW BOARD, KEEP IN MIND THAT IT IS VERY SENSITIVE TO STATIC DISCHARGE, SECONDLY, CONNECT THE RIBBON CABLE ON BOTTOM RIGHT OF BOARD ONLY AFTER ALL SCREWS ARE TIGHT AND OTHER CONNECTORS ARE SEATED ( MAKE SURE THE RIBBONCABLE IS FIRMLY SEATED AND LOCKED DOWN). AFTER INSTALLATION,CONNECT SET TO A VERY GOOD SIGNAL SOURCE, AND ALLOW SET TO WARM UP FOR ABOUT 20 MINUTES, THEN (USING LARGE, CLEAN MIRROR) SLIGHTLY ADJUST "SETUP AND SETDOWN" MINIATURE POTENTIOMETERS UNTILL THERE ARE NO SPARKLES.
GOOD LUCK!!
Oct 13, 2010 | Maxent MX-50HPT51 50 in. Plasma TV
The convergence is way off and will not adjust. Pulled and sent Sony the D board...new D board installed but did not fix the problem. Flash focus nor manual convergence will adjust. Have 3 images for...
Hi, thank you for visit fix ya.
Do you replace STKs ICs?.
If so, you need go to service menu tv.
With you tv off, press on your remote control:
display + 5 + vol+ + power.
You will go to service menu tv.
NOTE: Be Careful before you do this, because if you don't know step by step convergence adjustments.....YOU WILL MESSED UP YOU TV.
I recommended if you don't have electronics skill, take the tv near to tv shop.
Any question I will be here .
( I need model number tv, please)
Thank you
Jul 26, 2009 | Televison & Video
I have a Sony KP-51WS510 projection TV. The convergence was OK one evening, then way off the next day. I could not be adjusted. I pull the D board which has the convergence chip and sent it to Sony. I...
Hi, thank you for visti fixya.
Here is your solution:
Replaced, IC8001 and IC8002 Part number STK392-560 and check pico fuse beside STKs ICs ( yellow pieces), go to :
http://www.encompassparts.com/tritronics//
for parts.
I will be here for future questions.
Thank you
Removing the JK07132-A convergence board
Unplug TV from ac outlet for few hours, this will discharge caps in circuit boards and you can take out desired board after unplugging connectors.
Always Be Careful while doing repair in TV.
Dec 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problem with Samsung TV
SAMSUNG Convergence Problem
It looks like blue convergence. Look at menu, select convergence and see if blue top is bent down on convergence adjust screen. Probably won’t adjust.
Some Samsungs have convergence IC’s on a separate convergence board in the back of the TV. Others have the IC’s mounted on the main deflection board. Either way the board has to be removed to get at the dud IC’s and associated burnt resistors.
You remove the appropriate board, determine if any resistors are burnt or damaged, replace any burnt or out of tolerance resistors, replace 1 or 2 IC's and re-install the board.
Now you have to adjust it to look like new.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality, as it was before IC failed.
If after self or autofocus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
If convergence can not be adjusted properly, you messed up chip install or resistors may be wrong value or open; or it needs major adjustment.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
Jun 06, 2008 | Samsung HCN4226W 42" Rear Projection...
One color Bow-tie Effect.
If the unit has not been misadjusted and everything is OK now, running the auto focus may put the picture back to it’s previous stunning quality as it was before IC failed.
If after Perfect Focus it is still misadjusted noticeably, try the customer convergence adjustments. Operators’ manuals are available on web through searching.
Good Luck
easyab
Jun 05, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
May 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Convergence problems
Did you buy the board new or used? It could also be your convergence Ics and not the convergence that is causing the shutdown . The convergence ICs are not located on the convergence Board.
May 21, 2008 | Samsung PCN5425R 54" Rear Projection...
The display shows all the icons of the sytem and wont clear...
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Jan 09, 2008 | Samsung HT-X50 System
How do I replace the convergence board in this unit?
Yes the board can be replaced, but you may also need to do some touchup alighnment to the convergence, and maybe need to reprogram the magic focus or whatever the ato convergence is called on your set, if it has that feature, Good Luck
Jun 08, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
235 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
